Old 07-15-2010, 02:15 PM   #11 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by MARTINSR View Post
..........Now, honestly, with that little contact area, I would think these tires at the recommended air pressure would be pretty darn low LRR! What do you experienced guys think?
Brian
Google is your friend!
Bias tires have worse RR. I can't imagine that you can make up for the deficit just by the difference in tire sizing!
Old 07-15-2010, 03:00 PM   #12 (permalink)
The SHOW - '95 Ford SHO Taurus
But again, it is simply something I don't understand, not that I am challenging it. I will learn more about it when the time comes, my brain is overwhelmed with other stuff right now. But just at face value, a 20 sq in foot print of the little 5.90 bias plys seem to be less a rolling resistance than the 40 sq in of a radial of similar size. It doesn't seem to me that the advanced design of the tire could overcome that foot print.
Brian
Old 07-15-2010, 03:38 PM   #13 (permalink)
Tire Geek
CapriRacer's Avatar
....... But just at face value, a 20 sq in foot print of the little 5.90 bias plys seem to be less a rolling resistance than the 40 sq in of a radial of similar size.......
And that is where you need to start to understand this. ie. Are the footprints different sizes and if so, by how much? Does a factor of 2 seem right for the same size?
Old 07-15-2010, 03:46 PM   #14 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Brian
Brian, when you get a chance read through this - it explains it pretty well: http://media.wiley.com/product_data/...0471354619.pdf
Old 07-21-2010, 07:54 AM   #15 (permalink)
175-65-14 or something wouldn't be just fine. Only if you need new tires. Cost of changing tires just for mpg purposes is ridiculous, you never save enough gas to pay for the tires.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-26-2016 12:39 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 02:17 PM
New wheels and tires! Christ Off-Topic Tech 0 04-13-2009 11:30 PM
New Wheels & Tires trikkonceptz Success Stories 9 11-03-2008 03:05 PM
The finest Chinese cr*p that money can buy. (wheels & tires) lyd EcoModding Central 13 09-30-2008 06:41 PM
