Old 01-18-2021, 08:40 AM   #1 (permalink)
Joggernot's Avatar
Fold out extensions for vans, etc?
Dumb question 101: If the fold out extensions on the back of big rigs helps enough to pay for the extension, why hasn't someone come out with fold out extensions for vans, etc.
Old 01-18-2021, 10:29 AM   #2 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
My guess would be, lack of standardization of dimensions and shape. Trailers are typically the same dimensions with the same door design, so it's easy to market a product that will fit practically any trailer. To do the same for vans/SUVs, you would have to redesign (expensive) and manufacture (also expensive, especially in small quantities) a different mounting system for every model. Not to mention the extensive testing that would be required--Van A might achieve best drag reduction with panels of a different length or at a different angle than Van B.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 3 Users Say Thank You to Vman455 For This Useful Post:
aerohead (01-20-2021), Cd (01-18-2021), Joggernot (01-19-2021)
Old 01-19-2021, 01:02 PM   #3 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Joggernot View Post
why hasn't someone come out with fold out extensions for vans?
Because there would be no market for them. People in this country care more about looks than efficiency. On your next commute take note of all the full sized pick-ups and modified Jeeps that are used as daily driver/commuter cars.
Bondo created an aero topper for the Ford F-150 (the most popular vehicle in the US) but never realized widespread commercial success with it.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following 3 Users Say Thank You to COcyclist For This Useful Post:
aerohead (01-20-2021), Joggernot (01-20-2021), woodstock74 (05-19-2021)
Old 01-20-2021, 01:17 PM   #4 (permalink)
Bondo
Yep, he gave us 'CYBERTRUCK' in 2012, and there were only a few takers.
