Old 04-20-2008, 10:33 AM   #1 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Distributor Cap, Rotor: Replacement Interval?
I had the Distributor apart this week and noted the rotor to have a rough, rusty appearance at the contact point. The points looked OK, and it runs well.
Relatively little soot and dirt inside. 134K miles on the set. Replace it?
Vehicle in Question is Teggy.
EDIT: I split this into 2 threads, one regarding the timing.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
