Needed: CFD analysis on a SolidWorks assembly drawing
Unfortunately I have no way to perform a CFD on my assembly since I don't have access to FloWorks (the part of Solidworks that does CFD). So I am hoping to either find some free software that can perform the CFD from my .sldasm file or someone to perform the CFD for me to determine my project's Cd.
If you want to see screenshots of the project visit the Fossil Free forum for the post that involves my custom EV build or visit the blog in my signature. Thanks! |
I've got solidworks and floworks, I'll do the calculations if you want.
I should add I am a beginner, so if you let me know exactly what you need doing I'll be happy to give it a go. |
1 Attachment(s)
Awesome Dave!
I still need to clean things up and finish the rear of the vehicle. I also want to figure out how I can direct air around the wheels efficiently, so probably in a week I will try and hit you up on that offer and I'll send you a zip file of the whole assembly. Here's some eye candy from PhotoWorks. http://ecomodder.com/forum/attachmen...1&d=1237324023 I just started playing with those tools today so I'm pretty limited on what I've been able to do with that so far. It takes my computer about 4-5 images to render the images in Photoworks, but I think they will come out really nice once I learn all the in's and out's of that program. |
My friend made a fairly basic model of his Polo and it takes about an hour to do the calculations in FloWorks, and that's on my workstation (8 x 2.83Ghz).
Once I've worked out why I don't receive an email on new posts I'll look out for your reply. |
analysis
If you bear in mind VW's 1-liter car you could easily reach Cd 0.15.If you move the wheels out away from the chassis,mono-posto style and carefully fair in all suspension and wheels,you might squeeze Cd 0.11 as with Sylph.Go to the fish section of your supermarket and buy a frozen mackerel.You can take all your dimensions from that and scale it up.
I'm worried that putting the wheels on outriggers will increase the frontal area in way that is not offset by the decrease in Cd.
Thoughts? |
outriggers
I will have to think about it once I get a better idea on how my current build performs. The idea is to keep all costs down, so I certainly make all efforts to improve aerodynamics so that I can keep the drivetrain costs down. I think that having the wheels on outriggers and then trimming them out so that they are aerodynamic could be a bit cost prohibitive, but I think I will definitely play around with it when I get more fluent in Solidworks.
Good chance I will look into a larger 4-wheel design with fully inclosed wheels that has a bit more ground clearance then this design where the wheels will almost be like on stilts, kinda like Aptera's rearwheel except for all 4. |
I'll look it up =)
Copyright ©2000 - 2021, vBulletin Solutions Inc.
