Go Back   EcoModder Forum > AltModding > Saving@Home
Old 06-02-2010, 10:37 AM   #11 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Originally Posted by NiHaoMike View Post
A friend of mine is working on a hybrid A/C that uses evaporative cooling to cool the condenser of a normal A/C. The prototype gets a SEER rating in the low 30s. It uses distilled water as the refrigerant. Main problem is that the "turbocompressor" (basically a modified turbocharger driven by a switched reluctance motor) is not a mass produced part.
I think I'll try to build my own hybrid A/C in the future, but with a conventional refrigeration loop using ES-22a.
Not to rain on anyone's parade, but my rather ordinary, inexpensive Frigidaire window A/C has a COP of 10.5, or a EER of 36 and probably a SEER around 40. I hope he didn't worsen the COP by trying to evaporatively cool the condenser.
Old 06-02-2010, 12:12 PM   #12 (permalink)
Where did you get that A/C? Even high end central units are lucky to get 20 SEER. 30-40 SEER is about where geothermal is.
A simple fan can have an effective SEER rating much higher than 40, as can evaporative coolers. But evaporative coolers don't work in all areas and fans might not be enough on the very hot days.
Alternative to Air-con - EcoRenovator
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 06-02-2010, 03:26 PM   #13 (permalink)
Left Lane Ecodriver
Fantasyland. I'm a metric man living in a mixed-units world! Sorry, it's an EER of 10.5, for a COP of 3.1. I'm now properly impressed by that prototype condenser chiller.
Old 06-02-2010, 07:11 PM   #14 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
EER i assume is energy efficiency rating, but what is COP?
My burning question is the difference between using evaporative cooling to aid a heat pump type compressor and just using ambient air. if it makes a big enough difference I'd be all over it. Theoretically evaporative cooling will drop the temp by 10-12 degrees F regardless of humidity.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 06-02-2010, 07:34 PM   #15 (permalink)
Left Lane Ecodriver
Coefficient of Performance. It's the amount of heat energy moved from the A/C's cold side to its hot side, divided by the amount of electrical energy required to do it.
An EER is the same figure, but with one of the terms in BTU/hr and the other in Watts, and the units carelessly lopped off before doing the division. EER = COP * 3.413.
Old 06-09-2010, 11:08 PM   #16 (permalink)
Product Downloads | Coolerado Cool News
Looks like there's already a hybrid A/C in production. It appears to be roughly as efficient as the prototype unit my friend is working on. However, it is only available as a rooftop package unit instead of the more common split system. It must also be really difficult to install as it weighs almost as much as a small car! There's also no mention of price.
Old 06-10-2010, 04:07 PM   #17 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
Last time I crunched the numbers a grid tied (no batteries) system that size cost arround $25,000.
For the area I live in figuring a 20 year life span the power the system would produce would cost $0.20/kwh, or about double what I pay now. Arizona gets a little more sun than we do so that would reduce the costs, and I think Arizona has some extra deductions that we didn't get when I last did my calculations.
Before you get on me about using 20 years for a life span, its not that I don't think the panels can last 20 years, but that the chances of something damaging the system in 20 years is pretty good, be it a freak hail storm, neighbors kids with rocks etc... so I use a conservative 20 years.
Replace sunroof with solar panels to power AC? Luxbg EcoModding Central 6 08-19-2009 10:23 AM
nuclear plants groar The Lounge 76 06-19-2009 04:06 PM
