Old 01-26-2011, 07:14 PM   #1 (permalink)
Tiny - '91 Honda CRX HF
fueleconomy.gov (help finding CRX HF stats?)
Hello all, looking for a little help, I think I know the answer but would like confirmation! Ok on fueleconomy.gov when I look up a 91 crx HF it shows 2 models. I am assuming 1 of them is the federal model and the other is the California model. I am hoping this is so as I just purchased the federal ecu for my California car. Thanks for any help.
Old 01-26-2011, 10:54 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
You're right. Higher number is the 49 state model, however, the difference is not just the ECU.
Old 01-27-2011, 07:12 AM   #3 (permalink)
Please tell me the differences, now im curious!!! So will changing the ecu even help me?? Thanks
Old 01-27-2011, 08:40 AM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Probably just throw some codes and mess your engine up.
You also need the 5 wire o2 sensor. I believe that's it though.
Old 01-27-2011, 02:20 PM   #5 (permalink)
Alright now I'm 10 different kinds of confused!! I called 3 parts stores and they don't list different o2 sensors for a 91???? Can anyone else chime in on this? Thanks
Old 01-28-2011, 01:41 PM   #6 (permalink)
They didn't have 5-wire O2 sensors on cars in 1991. The HF uses the same narrow-band sensor that most cars on the road do. It doesn't run in lean-burn mode, it just has a small engine geared very tall pushing a lightweight and somewhat aerodynamic shape around.
I believe that one of the differences between the 49-state HF and the CA-spec one is that the CA one is geared slightly shorter. Though I have read conflicting information on that...
-soD
crx hf
