Old 01-07-2010, 04:04 PM   #1 (permalink)
rusty - '00 ford mustang coupe
90 day: 24.31 mpg (US)
cbr929 - '00 honda cbr929 fast
90 day: 39.54 mpg (US)
Porshe - '06 Kawasaki zx10r
90 day: 47.21 mpg (US)
truck - '96 ford ranger
90 day: 26.51 mpg (US)
Ceramic coating the intake and engine block
and/or pistons and comb chambers.
Do you guys think it's a good idea? If so why and why not.
Thanks.
Old 01-07-2010, 04:22 PM   #2 (permalink)
Coating the pistons and chamber will help, but probably not noticeably. However, coating might help you increase compression ratio which could have a larger effect on mileage.
I haven't heard of coating your block or intake, and I'm not sure why you would.
Old 01-07-2010, 06:55 PM   #3 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Combustion chamber, piston dome and ex valves helps if you're boosting and running lean. If you are doing a home-brew lean burn, it may save your engine.
For all around better fuel usage, spend the money on ceramic coated tube headers. The retained heat keeps the exhaust velocity up.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
The Following User Says Thank You to JasonG For This Useful Post:
dave77 (01-08-2010)
Old 01-08-2010, 11:25 AM   #4 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
You can also get a moly coating on the piston skirts that will reduce friction. Typically when the combustion chamber is done they coat both intake & exhaust valves.
It also makes it a good time to get a 5 angle valve grind on the exhause valves.
The Following User Says Thank You to DonR For This Useful Post:
dave77 (01-08-2010)
Old 01-08-2010, 12:57 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
nemesis -
This makes me think of the following scenario. I have an engine with 190K miles on it, so it's gotta be a bit worn. If I needed to do a rebuild, then maybe this would be a good thing to do *during* the rebuild. That way, in theory, I could beef up the engine to good or better than new.
CarloSW2
American Solar Energy Society
Old 01-08-2010, 01:01 PM   #6 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
i get what you're saying with the block and intake I think coating it would keep the motor heat in possibly and increase mileage
If you already have the motor out of the car it's worth a shot
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 01-08-2010, 01:07 PM   #7 (permalink)
Heat is energy, and I am not filling the car up with gasoline to heat my engine compartment, plus the engine will stay hotter when it's off, so the warm up won't even be necessary.
Old 01-08-2010, 01:27 PM   #8 (permalink)
There are much cheaper and better ways of insulating your engine if that is all you are looking for. Ceramic coating will actually not do a ton of insulating since the layer is so thin. You need something thicker if you really want to insulate it.
Old 01-08-2010, 01:34 PM   #9 (permalink)
What do you think would work better?
Old 01-08-2010, 01:46 PM   #10 (permalink)
Here is something an Insight owner came up with.
Randall's Insight - MIMA Honda Insight Modified Integrated Motor Assist
Efficient Engine Design ??? pgfpro EcoModding Central 110 02-12-2010 01:53 PM
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 01:22 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
