Old 03-24-2019, 10:39 AM   #1 (permalink)
new to ecomodding, 2012 prius
I'm new here and just thinking about doing some small things to help out with fuel economy. I'll be looking around for ideas. Driving a 2012 Prius with 89K miles. Any advice for beginners is welcome. Thanks
Old 03-24-2019, 02:12 PM   #2 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
There isn't a whole lot of simple mods you can do to a Prius to improve it's efficiency. It's already an efficient motor with a computer managing the hybrid system for maximum efficiency.
Inflating your tires to sidewall max should help. In my mom's '08 Prius, inflating the tires from 36 PSI to sidewall max of 50 PSI showed a tested improvement from 43.8 MPG to 47.6 MPG at highway speeds, with new winter tires, in semi-wintry conditions with temps hovering in the 30s F. Subsequent drives outside of testing have favored the theoretical 3 MPG improvement.
Strategic grille blocking helps the car warm up to it's optimal running temperature faster, but you would need to monitor coolant temperatures to ensure that you aren't blocking off too much of the grille.
Larger things would include pulse-n-glide driving, lighter wheels, skinnier tires, boat tail, etc., but those are generally considered to be more radical and expensive.
And as always, the 100+ Hypermiling Tips page on this site has many great ideas and solutions.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
The Following User Says Thank You to mpg_numbers_guy For This Useful Post:
islandhostage (03-24-2019)
Old 03-24-2019, 03:55 PM   #3 (permalink)
90 day: 33.31 mpg (US)
90 day: 62.22 mpg (US)
Get yourself a ScanGauge and monitor your coolant temps as you grill block. I've run 100% grill block on my 2012 Prius and temps are fine in the winter unless I'm headed up a mountain.
