Old 06-16-2011, 02:38 AM   #11 (permalink)
Enthusiast
What they said. If you really want to build a transmission, go over to d-series.org and read up on the transmission build threads. They are typically building for high power and shorter gearing, but the same skills would apply. You can do it yourself if you'd like. Get ready to spend some quality time, though.
The Following User Says Thank You to hondaguy72 For This Useful Post:
California98Civic (06-16-2011)
Old 06-17-2011, 08:50 PM   #12 (permalink)
I talked to a guy in north carolina recently who was selling his 5th gear. I was interested in doing something similar to what your talking. He explained after swapping in the 5th gear from a hf into his crx dx the results weren't even close to his expectations he said it only lowered his rpms @ 60mph by about 200rpms. I wish I could remeber his explanation clearly but I can't. Bottom line from someone who did it. swap the entire trans. I have since purchased a hf trans for my 87 crx si.
Your only as good as your last mistake
Toying with idea of taller Metro 5th gear (to go with the already taller final drive) MetroMPG EcoModding Central 106 02-20-2020 12:29 PM
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 36 02-11-2015 11:08 AM
'93 Civic 40.6 mpg + Harbor Freight utility trailer, Honda CL125, Honda CH80 scoot begreen Introductions 13 08-29-2013 06:37 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Honda Civic VX/VEi comparing to Diesel- Top Gear Review form 1991 XyKo General Efficiency Discussion 2 10-06-2009 02:13 AM
