A New Internal Combustion Engine Allegedly Produces Nearly Zero Harmful Emissions
That doesn't sound possible. A Civic engine can put out 160 HP, but weighs over 300 pounds. 8.6 times the power-to-weight?! |
I agree it doesn't sound possible. I'll watch the videos later. Can I reserve an Elio with that engine? :D
I don't understand how the cool side and hot side are connected, but it strikes me as similar to the Scuderi/Entry Combustion designs that separate the two, on a crankshaft.
Also don't understand why the two rotors are hollow. :confused: |
Good find... :thumbup: More info and videos here. https://www.astronaerospace.com/ Edit. The first 30 minutes of this video are very interesting... https://youtu.be/_LkkjYParp4?t=170 :turtle: > . |
I went back and Thanked Xist too. :thumbup:
So it is a Brayton cycle, just translated away from the rod and wheel paradigm. I still don't understand the hubless design, but maybe it has something to do with the aviation focus. Quote:
What's next, someone brings up RWTHs IKV engine?
Yes Aviation. Think rocket engine... Hollow rotors with added bell shaped nozzles for thrust. (afterburners) Run as a internal combustion engine as high as possible (100,000 ft. ?) Quote:
Very cool... 😎 > . |
They would have to sort out what your referent might be. redneck -- Single stage to orbit, like the UK Skylon? I was thinking more along the lines of Jetoptera. If it exhausts into the central flow does that make it a complicated pulse jet? Edit: quote: "It's fun to work with people who know what they are doing." Matthew Riley, Astron Aerospace 2nd edit: Okay, I need to get my 3D printer up and running. A proof of concept model seems achievable, but with lost PLA casting techniques, a hubless bicycle wheel motor is within possibility. You couldn't sell them because patents, but one could make one's own. Since they spin in opposite directions the air flow should be opposed, so a rear wheel motor could blow into 90˚ elbows. ....with afterburners! |
emissions
Perhaps they didn't get the memo about carbon dioxide.
And competing against 'engines' with a BSFC-e of 0.0795 lbs/ bhp-hr should be interesting. 'I pity the fool!' Mr. T |
Perhaps they did. Did you catch the part about Hydrogen?
