Old 05-03-2014, 04:15 PM   #11 (permalink)
118 mpg front end
You might just fab up a cardboard and duct tape nose mockup and see how it shows at the pump.
Conventional wisdom does suggest that it would be hard to see on the radar screen of mpg,however,there are a few extant studies in which reversed streamline bodies were wind tunnel tested.While their drag was significantly higher than 'tail-behind' bodies,when wheels are added the difference diminishes.
It might be possible to get to around Cd 0.13 like this,where you might go below Cd 0.10 with the tail where it belongs.
Just not a lot of data on this sort of thing.
Testing after nightfall might reduce anxiety.
Old 05-03-2014, 04:35 PM   #12 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Best mpg is going to be with the stock exhaust. Anything larger and its going to stagnate at our rpms. Tuck and rotate it as needed for the belly pan.
Shooting for 600 miles of range at 65-70 mph out of a vx.
