Old 03-18-2009, 10:05 PM   #1 (permalink)
GreenMile - '00 Mazda Protege ES
90 day: 34.45 mpg (US)
New steering system concept to minimize aerodynamic drag
So the basic idea is the total elimination of wheel skirting and minimizing the underbody gap with the wheels. The below photo is just a sample of the concept. There are other ideas that I am thinking about to implement in conjuction with this that I may design later on.
My main concern is the handling during the turning and wondering if it effectively narrows the front wheel base.
What do you think?
http://benw385.vox.com/
'Blog' on the open source electric motorcycle project.
Please come visit and comment!
Old 03-19-2009, 02:53 AM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
So you're proposing to keep the wheels stiff and articulate the vehicle in the middle, like some construction trucks? Sounds a little complicated . Judging by your picture, if you start turning left, then something sticks out on your right. Maybe if the car body was flexible?
Old 03-19-2009, 03:07 AM   #3 (permalink)
The steering mechanism that I have in mind is actually pretty simple but more on that later.
Old 03-19-2009, 03:21 AM   #4 (permalink)
I think it would be easier and more effective to fair in the wheels and suspension of the regular steering types.
Old 03-19-2009, 05:44 AM   #5 (permalink)
Hi,
Can you clarify what we are looking at, please?
Old 03-19-2009, 06:45 AM   #6 (permalink)
You are looking at the birds eye view of rough car design shape. The entire front end turns in relation to the rear, the wheels in the front would remain stationary to themselves. The intent is to completely enclose the wheels for aerodynamic purposes.
I should have something better in a couple days that demonstrates the concept much better.
Old 03-19-2009, 07:22 AM   #7 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 Honda City iDSI EXi
90 day: 47.47 mpg (US)
Hey Blue Bomber, it looks like even small angular movements of the steered section would expose a sharp protrusion on one side of the vehicle to the air flowing past - bad for a streamlined, attached flow.
Maybe you should consider flexible overlaps of the steered section skin over the trailing section, so that the protrusion can be smoothened over. You are a smart man so will get what I am vaguely describing without a diagram to explain...
Old 03-19-2009, 08:40 AM   #8 (permalink)
I realize that the edge would stick out, but it would only be significant at lower speeds when smaller turning radii's are used. At higher speeds the turning radius is much larger and thus requires less turn angle.
Also I think I can design it so there is no edge/gap on either side of the vehicle even when positioned to turned to full. I think it will require some geometry that is a bit more complicated then circle but I pretty sure it could work.
Old 03-19-2009, 09:10 AM   #9 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
Not sure I completely follow.
Where is driver's seat located?
How many wheels? Located where? How are they oriented in each view?
Answering the above questions with block diagram additions to your drawing would be much appreciated.
TIA
Old 03-19-2009, 09:24 AM   #10 (permalink)
Originally Posted by Blue Bomber Man View Post
...I think it will require some geometry that is a bit more complicated then circle but I pretty sure it could work.
I think it would be a complete semicircle that would do the trick, rather than a shallow arc currently depicted. But then it might be too inefficient in using space available.
CdA list Daox Aerodynamics 206 10-25-2023 06:32 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
BMW cooling duct fabrio. Aerodynamics 19 09-27-2008 04:48 PM
aero-mods,installment#9(internal drag) aerohead Aerodynamics 39 07-11-2008 05:45 PM
Cooling system drag Daox Aerodynamics 7 01-29-2008 09:01 PM
