Old 05-23-2019, 10:07 AM   #1 (permalink)
Redneck Ecomodder
3 Cyl Metro Pull Start?
I had another crazy idea for my metro. To eliminate the battery and the maintenance that comes along with that, I was thinking I could install a lawnmower style pull start. I'd probably just use a small capacitor in place of the battery for the sake of current flow while running. This would eliminate the issue of of the alternator constantly working to charge a 12v battery to 14v. This also would mean no worrying about a dead frozen battery in winter.
Thoughts?
Old 05-23-2019, 12:48 PM   #2 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
You would need a destroke lever so you could reduce the kick
You would also need a magneto to run the spark until ecu wakes up
The Following User Says Thank You to rmay635703 For This Useful Post:
KrautBurner (05-23-2019)
Old 05-23-2019, 01:22 PM   #3 (permalink)
90 day: 29.78 mpg (US)
That doesn't solve the problem of losing memory presets, which is among the reasons to have a battery. If you don't care about that, then you could just use a detachable battery or supercap. Heck, if the parasitic drain is extremely low, you could probably just leave the supercap in and it would hold enough charge to start the car even after sitting a couple weeks.
My truck is down to about 5 mA parasitic drain (radio), so it could theoretically run off supercaps alone.
Old 05-23-2019, 01:53 PM   #4 (permalink)
Redneck Ecomodder
I don't think the ECM runs the spark on these cars? maybe so but I figured they weren't as it has a distributor.
As far as presets....I don't even know how to turn the radio on in this car (very old aftermarket CD player.) I have 4 kids at home, my commute is my time to have quiet, aside from the drone of the 3-cyl.
Old 05-23-2019, 02:24 PM   #5 (permalink)
I'd start by measuring your parasitic drain with a multimeter. If it's low, you could try a 6-series 350 farad supercap bank. Should work fantastic in your cold winters...
Of course, you'd want to disable your dome lights (or go LED) and be careful about anything else that might turn on when you open doors, etc. That will very rapidly drain a supercap.
Old 05-23-2019, 02:30 PM   #6 (permalink)
KrautBurner's Avatar
Cavalier of D00M - '05 Pontiac GTO LS2 T56
90 day: 23.2 mpg (US)
The New One - '10 Toyota Prius II
90 day: 51.55 mpg (US)
Chick Magnet - '91 Geo Metro 3cyl/5sp
90 day: 48.07 mpg (US)
bettery delete
I'd skip the "pull start" and consider one of the battery pack jump starters
still using a capacitor for your electrical load
https://www.amazon.com/GOOLOO-SuperS...=fsclp_pl_dp_2
2005 GTO 6.0 V8 (600hp)
1991 Geo Metro 1.0 3/5 base
2010 Prius II (replaced 2001 Tahoe 5.3 V8 April 2014)
1994 F-350 7.3 TurboDiesel (Rollin' Coal)
Old 05-23-2019, 02:36 PM   #7 (permalink)
Redneck Ecomodder
Actually the dome lights is what made me think of it. Of all things this car does not turn on the dome light when the door opens, but it does have an idiot light to show the door is open if the key is on.
Old 05-23-2019, 02:38 PM   #8 (permalink)
pocket jump starter
I think I like this one even better
https://www.amazon.com/dp/B07MNKH8PK..._t3_B076PR52Z7
With a peak of 800 Amps – it’s able to jump start flat batteries up to 20 times on a single charge. Work with all 12V battery cars, trucks, motorcycles, snowmobiles, ATV, UTV, lawn mowers, yachts and heavy duty
they have larger ones too
800Amps
$49.99
1200Amps
$64.99
1500Amps
$79.94
2200Amps
$129.94
Old 05-24-2019, 07:33 PM   #9 (permalink)
rmay635703's Avatar
Old 05-24-2019, 11:53 PM   #10 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Originally Posted by rmay635703 View Post
Those guys did a pretty lousy job of actually hooking things up, I just found some other videos of predator swaps in cars where they did things properly. Here is one:
5 speed transmission, centrifugal clutch, and the throttle is hooked up(duh!). You can shift on the fly!
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
The Following 2 Users Say Thank You to Daschicken For This Useful Post:
Frank Lee (05-25-2019), samwichse (05-25-2019)
