Old 02-14-2012, 06:09 AM   #11 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 76.91 mpg (US)
Send a message via MSN to jakobnev
PV=nRT
text
Old 02-14-2012, 07:35 AM   #12 (permalink)
Ed-in-Maine's Avatar
Iceberg - '02 Ford F250 XLT
Pickups
90 day: 18.3 mpg (US)
Tool - '08 Toyota Matrix XR
90 day: 43.15 mpg (US)
I ran N2 in the tires of an RX7 Spec racer back in the early 1990's. It was an experiment. In racing conditions i.e. big fluctuations in tire temperatures it helped since the N2 didn't change pressure as much due to temp. SO it saved a ton of messing around to get the tires pressure set up. But back then it was expensive an not easy to get.
Today in everyday street cars, I suspect like others have said it's all about marketing. I'm not sure half the population even knows what a Turbo is and don't get me started on this "i" nonsense.
But all else being equal I'd take it. I've have no problem telling the service center NO to all the other BS things they would like to charge for.
Ed
Old 02-14-2012, 08:41 AM   #13 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
The main effects I've noticed when comparing compressed nitrogen to compressed atmospheric air is that when installed in a new tire, the tire with compressed air will lose about 10psi (when initial pressure is 60psi) over the next 6-8 months as the oxygen in the air oxidizes the interior rubber of the tire and is removed from the gas mixture inside the tire. This oxidation caused pressure drop diminishes with time and is negligible in a 5 year old tire.
The other main difference is in the humidity (dewpoint) of the gas in the tire. Compressed nitrogen is generated by boiling liquid nitrogen and so has zero water content. Most garage air compressors just compress the local atmospheric air and don't have an air dryer inline to remove the excess water. Atmospheric humidity rises as the pressure increases, so the 40% relative humidity in the garage's air is over 100% by the time the air compressor has bumped the pressure up to 140psi and put it in the storage air tank (they have to drain the accumulated water from the storage tank from time to time). This humidity drops some when you fill your tire from the storage tank, but the humidity of the air in the tire is still well over that of the initial garage atmospheric air. You can sometimes see this humidity in the air when changing tire as the garage pulls the valve stem and the air rushes out of your tire. This increased water content in the compressed air in the tire is just another gas in the mixture and will react like any other gas to temperature changes. Any corrosion it might do to any exposed steel on the inside of the wheel would end once all of the oxygen in the tire has reacted with the rubber and exposed steel.
I don't see how nitrogen could show much difference in pressure fluctuation with temperature changes when compared to atmospheric gas. All gases follow Charles's gas law and any deviations of nitrogen from that of an ideal gas would be minor.
aerocivic.com
Old 02-14-2012, 10:04 AM   #14 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
Originally Posted by jakobnev View Post
PV=nRT
Who are you calling a pervert?
Old 02-14-2012, 11:05 AM   #15 (permalink)
Smash 100 MPG barrier
mbrac's Avatar
Frankie - '07 Ford Focus SEL
Tire Barn
Originally Posted by jamesqf View Post
On the other hand, how much mpg will you lose, riding around on underinflated tires until you can get into the dealer to have them inflated with pure nitrogen, instead of the 80% nitrogen you can get everywhere?
And I bet the dealer won't inflate them beyond the too-low manufacturer's recommended pressure, either.
I got my tires at Tire Barn - I think it's a national chain - but they will let you inflate yourself to what ever pressure you like - I run mine about 5-6 lbs. over manufacture recomended - just saying.....
Old 02-14-2012, 01:04 PM   #16 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I'm having a tough time accepting serious improvements from N2 over (dry) air - given the equally common air on the outside of the tire.
Water vapour will make a difference, especially when it transitions between the gas and liquid phases due to temperature.
One of my previous cars sat mostly disused for nearly 2 years.
Its rear tires stayed on long enough to show signs of rubber rot and cracking on the outside , but when they got replaced, the insides were just about as pristine as the new tires.
Why not fill up the tyres with atmospheric CO2
