Old 10-01-2011, 05:44 PM   #1 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
Screwed up
I have been playing with my motorcycle for the past few months and have neglected one detail on my car....... you guessed it, tire pressure.
Can't really say that I felt something was wrong because your brain adjusts slowly to a slow change, but my coast distances seemed 'off' and I did not think the tires would have lost SO much pressure. They looked fine, but when I applied the gauge to them this morning I was shocked they were 10 psi off what I normally run them at, and 4 psi under where you initially feel the coastability difference.
So, aired them up and just releasing the clutch I could feel the rolling difference.
Was even more shocked when rolling through the neighborhood.
Before getting back into motorbikes, I checked the pressure every other day.
It makes a massive difference, so keep track of it.
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
Old 10-01-2011, 07:04 PM   #2 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Mine too were low by as much as 10 psi.
Old 10-01-2011, 07:21 PM   #3 (permalink)
Rick323's Avatar
Black Cruze - '18 chevrolet cruze ls
90 day: 37.98 mpg (US)
The Ram - '22 ram 2500 tradesman
90 day: 12.35 mpg (US)
I used my truck a month or so ago to get some firewood. I didn't check the tire pressure before I used it. When I was in the woods, I just thought my tire was parked on a rock or something, it looked flat. Finally after moving the truck and the tire still looking flat, I decided it was flat. I nursed it home (7 miles) and tire pressures were as follows--45psi (normal), 25psi, 20psi, and the flat one 12psi. Before using the truck for firewood, the truck sat for a month and a half in my barn.
Old 10-01-2011, 07:35 PM   #4 (permalink)
...beats walking...
...somebody (other than OnStar™) needs to market a "Tire Pressure" app for smart-phones!
Old 10-01-2011, 07:56 PM   #5 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
why dont you just 'schedule an appointment' with your tires on your calander??
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 10-01-2011, 07:58 PM   #6 (permalink)
My 2008 Altima sat for 10 months before we finished repairing it and got it back on the road. I was amazed that the tire pressure monitoring system did not show a single tire to be low on air. I keep them at 40 PSI and have never seen them loose more than maybe 1 PSI a month.
My experience has been that when you change tires it's a good idea to clean the bead seating portion of the rim very carefully to make sure there are no rubber fragments left from the previous set of tires.
Seems to make a difference in long term pressure retention, if you actually have the opportunity to thoroughly clean the bead portion of the rims, as well as the area where the valve stem seats on the rim, especially on older cars and trucks.
Slow leaks can be hard to find, but the old sink it in a water tub will still find them if you are patient enough.
regards
Mech
Old 10-02-2011, 11:10 AM   #7 (permalink)
...beats walking...
...rule-of-thumb's are:
-1 psi per month
-1 psi per -10ºF
Old 10-02-2011, 12:06 PM   #8 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
regards
Mech
Adding a little soap can make it even easier.
