Old 03-19-2011, 06:18 PM   #1 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.65 mpg (US)
It was NOT the synthetic oil
Once upon a time, I had a Honda CB350. That bike averaged 60 MPG in a mixture of city and highway driving. I didn't specifically try for mileage, but did not drive it hard either.
I wanted to find if Mobil 1 synthetic would get better gas mileage. So I started with a pair of baseline MPG tests:
30 MPH 87 MPG
60 MPH 60 MPG
Changed to Mobil 1 and reran the MPG tests:
30 MPH 103 MPG
60 MPH 63 MPG
These results did not make sense until I realized that I was getting better at holding a constant throttle position. This was especially tricky at 30 MPH, because the throttle was barely off idle.
This could be called an A-BC test. It shows the need for careful testing of changes (see the How To Properly Test sticky in Ecomodding Central).
CONCLUSIONS
1) The Honda CB350 responds very well to a steady hand on the throttle.
2) I still have no idea if the Mobil 1 oil caused better gas mileage in that bike.
Old 03-19-2011, 07:23 PM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I too had a CB350 for a while but never saw 60mpg, I tended to average 45-50mpg, the thing with synthetic oil is that alot of it will ruin the wet clutch of a motorcycle if it has friction modifiers in it, so just a word of warning, I've replaced two wet clutches for this reason.
But you are right, the CB350 has constant velocity carburetors, so a slight twitch of the throttle would make it open up the diaphragm and thus open up the needle for the main jet in the carburetor, dumping in extra fuel.
