Old 05-23-2009, 04:58 PM   #1 (permalink)
Princess - '08 Chevy HHR LSSR
90 day: 23.66 mpg (US)
O2 Sensor problem Need help!
I have an 08 Chevy HHR with the 2.2 Ecotoec engine. I love it and have made a bunch of changes to improve mileage. Now I have run into a problem and hope someone here can help. My mileage has been down some latetly. Did a data log on it and it shows fuel trims on the lean side so the ECU is adding additional fuel and hurting mileage some. The O2 sensors says it is a little lean. The car only has 25,000 miles so I would think the O2 sensor is still good.
Any suggestions on how to correct the problem?
Thanks in advance. Curly
Old 05-23-2009, 06:50 PM   #2 (permalink)
The 02 sensors should still be good. Usually if an 02 sensor goes bad it will have a drastic effect on FE, usually causing a 25-35% drop. If the 02 sensor is bad you also should have a CEL. The plugs should still be in good condition, but you might want to pull them out take a look at them, clean them and regap them.
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
Cleaning o2 (wideband in this case) sensors? Daox General Efficiency Discussion 2 05-20-2009 07:42 AM
single wire o2 conversion to 3/4 (heated) getnpsi DIY / How-to 14 12-04-2008 02:56 PM
How to test O2 Sensor? SirKeats DIY / How-to 3 05-28-2008 12:25 PM
Running "Lean" with a Resistor Divider on the Air Temp Sensor steensn EcoModding Central 22 05-16-2008 09:11 AM
