Old 01-25-2012, 01:38 PM   #21 (permalink)
...beats walking...
...start small, grow BIGGER.
Old 01-25-2012, 05:42 PM   #22 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Diesel_Dave -
That's a really good price. I remember when $50 for the connector and $50 for the software was a "bargain". The pro version looks cool too.
CarloSW2
American Solar Energy Society
Old 01-25-2012, 06:01 PM   #23 (permalink)
The pro version does look cool. If I can make custom gauges that will display in real-time (the included gauges with many of the OBDII loggers/software kinda suck), I'm sold.
Old 01-25-2012, 08:18 PM   #24 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
mbrac, can you make custom screens/gauges with the basic version, or can you just select various pre-defined displays?
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 01-26-2012, 08:18 AM   #25 (permalink)
Smash 100 MPG barrier
mbrac's Avatar
Frankie - '07 Ford Focus SEL
No custom screens - but what comes with is more than enough for seeing what you need in real time - I'd recommend getting it and see if it does what you need - if not - then srping for the pro version -
The Following User Says Thank You to mbrac For This Useful Post:
Diesel_Dave (01-26-2012)
Old 01-26-2012, 11:10 AM   #26 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
I was able to make custom guage screens with the version I have, I wasn't able to however put in a correction factor on the speedometer to correct for tire size. That was limited to the upgraded version.
Old 01-26-2012, 11:18 AM   #27 (permalink)
mbrac's Avatar
In that case - I stand corrected - I didn't know you could do that - I'm pulling up the GUI now to take a look - how exciting if taht is the case!!!
lamb.chop (01-30-2012)
Old 01-30-2012, 09:44 AM   #28 (permalink)
Okay, I got mine now and kicked the tires a little today.
The first thing I noticed is that on my truck, the OBD port is located in such a way that the cord hangs down right in front of the clutch pedal. I had to kind of twist my foot to reach the pedal with my toes. I also bumped the cord out with my leg once. I'm thinking about seeing if I can relocate the OBD port for convenience. Anybody else had this problem?
Also, has anybody used this on a diesel? It was 3 fuel options: Mass air flow, IMAP, & direct. I assumed a diesel should use the direct method, but when I use it it just gives me 0.0 mpg and fuel flow of 0 gal/hr. However, at the end of my trip, the trip summary screen (I can't remember the exact name) said the mean fuel flow was 0.8 gal/hr, which is very reasonable. I also tried usring the MAF & IMAP settings, but they gave bogus numbers like a trip mpg of 700 mpg.
Anyway, guess I got some troubleshooting to do...
Diesel Dave
Old 01-30-2012, 09:48 AM   #29 (permalink)
mbrac's Avatar
I moved my connector to behind the dash - and then routed the cable to the netbook - so it's out of the way - and looks clean - but sorry - have never tried it on a diesel
Old 01-30-2012, 01:30 PM   #30 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Diesel_Dave -
Mine's on the way. I thought this would be a problem, but I was waiting to see. I think you need to get an extender cable that has an "L" shape instead of sticking right out :
BMW E38 740iL M62 4.4L > Engine > Tools > ES#9485 Six Foot OBD II Extension Cable - S1535
This ECS OBD II 6 foot extension cable allows you to place your connection out of the way of your legs on the driver's side of the car. This extension cable is 6 foot so it allows you to place your connection/laptop on the passenger side if necessary.
$29 sounds like too much. There's gotta be a cheaper cable ... Ah, fleabay :
2' Right Angle OBD 2/J1962 Male-Female Cable Scan Tool OBDLink SX ELMScan 5 | eBay
$12 makes it useful for other things.
CarloSW2
The Following User Says Thank You to cfg83 For This Useful Post:
Diesel_Dave (01-30-2012)
