Old 09-01-2022, 02:41 PM   #1 (permalink)
OEM-quality pickup mods
Ran across this. Really nice build quality.
https://grassrootsmotorsports.com/fo.../176802/page1/
Old 09-01-2022, 03:58 PM   #2 (permalink)
That is a Ute conversion? It's really bad. Compare: https://www.smythkitcars.com
This was on Just A Car Guy today:
door panels and center console pieces created with Precision Board PBLT-25 (25lb)
I think this is the same stuff Arcimoto use for their fenders and door panels. Thermoformed Urethane foam come to the masses.
aerohead (09-01-2022)
Old 09-01-2022, 04:06 PM   #3 (permalink)
created with
Did they use a $250,000 five-axis router to create tooling from the 25-pound density board, from which they vacuum-formed the pieces?
Old 09-01-2022, 04:45 PM   #4 (permalink)
Arcimoto use such routers to make aluminum forms for the sheets to be thermoformed over.
You can see a pallet of sheets in lower left. Upper left you have a yellow robot arm which will eventually take the formed sheet output and place it on a new machine to the left where it will be trimmed and holed with a CNC router. That station uses a less expensive form as it only holds position.
Old 09-02-2022, 01:43 AM   #5 (permalink)
Interesting but often disturbing topic.
https://gmauthority.com/blog/2020/05...little-pickup/
https://gmauthority.com/blog/2019/04...impersonation/
https://www.holley.com/garage/view/4...rolet-caprice/
More my style below.
https://gmauthority.com/blog/2022/08...s-up-for-sale/
aerohead (09-06-2022)
Old 09-03-2022, 12:04 AM   #6 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
Those are disturbing on many levels.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
