Old 12-29-2010, 12:15 PM   #21 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Mario_Marques -
Originally Posted by Mario_Marques View Post
One question, your scangauge works independent from the car ecu?
Yes, but it only gets a subset of information from the ECU. It gets data from the OBD-II port that the ECU is required to give because of OBD-II specification. The scangauge does *not* get fuel-injector pulse widths, so it has to figure out the fuel consumption using a formula that is indirect.
"the scangauge has a formula that depends on a real IAT temperature."
If your car ecu manage the fuel mixture like the scangauge, could be real mpg values, it depends on how your ecu calc the air/fuel, i don't know how a aftermarket scan gauge work but i thing they probably use the same method as cars
I agree the car ECU uses the other sensors to manage fuel consumption. This would be very true in open-loop mode. But I think closed-operation is *the* dominant factor in my gasoline car :
http://www.autoshop101.com/forms/h58.pdf
More on closed-loop operation :
Answers.com - What is closed loop mean as in vehicle
Closed Loop Operation
Tech - Closed Loop
ShadeTreeMech -
Thanks for the diesel/gasser comparison information. I definitely think the mods effect different drivetrains in different ways. A mod for a diesel may not work for a gasser. The reverse is also true.
CarloSW2
American Solar Energy Society
