Old 02-06-2010, 05:08 PM   #1 (permalink)
Cycling more to drive les
White 'rolla - '05 Toyota Corolla LE
90 day: 44.39 mpg (US)
Send a message via AIM to Chalupa102
Making a better belly pan
I finally got around to getting some new coroplast today and am making a better belly pan in the front than what i had. Eventually i'm gonna do one for the rear as well.
I remember reading somewhere that someone got worse f/e because it had a parachute affect, so i believe they added a reverse scoop. Will i need one as well to release air coming in so it won't get trapped?
I do have my grills blocked right now, at least for the winter and the top one will remain blocked throughout the summer.
Corolla aeromods thread:
http://ecomodder.com/forum/showthrea...ead-11210.html
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Belly pan soon White118 Aerodynamics 19 07-21-2011 12:54 PM
Aerodynamic Belly Pan on Toyota Echo jime57 Aerodynamics 23 12-05-2010 06:18 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
