Old 09-21-2013, 02:02 PM   #1 (permalink)
cfdguy - '13 VW Golf TDI
50 mpg at 80 mph (project 2013 Golf TDI aero mods)
This is going to be my project thread. My goal is to average 50mpg at 80mph in my TDI Golf. I am currently averaging 47mpg at 70mph. This project will strictly be aerodynamic widgets to achieve this goal.
I will initially be starting with the current car in CAD. Running a cfd analysis on it and comparing to analytical data found on the car.
My goal will be to have all the aero widgets under the car so they cannot be seen
CAD: Solidworks 2013
CFD: OpenFOAM
Current CAD Model:
The CAD model still needs wheels modeled and such but it is close. I have access to a 3d scanner and a 3d printer. All widgets will be 3d printed and tested before actual parts will be made
The Following 6 Users Say Thank You to cfd_guy For This Useful Post:
AndrzejM (10-03-2013), Insight for life (09-21-2013), JasonG (12-13-2013), Jyden (11-23-2013), mcrews (12-13-2013), mikeyjd (09-21-2013)
Old 09-21-2013, 03:32 PM   #2 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
mighty impressive !
Old 09-21-2013, 03:40 PM   #3 (permalink)
Check out member Vekke's work with his VW. 50 at 80 is a tall order but good luck trying!
regards
Mech
Old 09-21-2013, 10:33 PM   #4 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
If you are willing to add an aero widget that can be seen (a boattail), you could raise your goal even higher. The Aerocivic gets lower 60's mpg at 80mph.
aerocivic.com
Old 09-23-2013, 08:21 AM   #5 (permalink)
90 day: 51.82 mpg (US)
50 at 80 is a tall order when restricted to "hidden" aero mods, but should be fun trying for it.
I've been waiting for someone to take this approach. This will be the best route to sharing mods in the future.
Watching with interest!
Old 09-23-2013, 09:26 AM   #6 (permalink)
bryn's Avatar
sputnik - '93 oldsmobile silhouette
90 day: 23.23 mpg (US)
home sweet home - '92 ford clubwagon E-350 xlt
very excelant - '92 honda civic vx
i know you are only talking aero at this point, but i would love to see 80mpg at 50 mph. i wonder which you would get to first?
The Following User Says Thank You to bryn For This Useful Post:
mcrews (12-13-2013)
Old 09-23-2013, 04:04 PM   #7 (permalink)
OldContinents
Did anyone fancy evaluating this statement with the appropriate tool ?
I threw some numbers at it and found out the following is required to hit 50mpg @ 80 mph
Vehicle weight [1]: 1200 Kg
Crr - Coefficient of rolling resistance [2]: .008
Cd - Coefficient of drag [3]: 0.30
A - frontal area [4]: 2 sq meters
CdA 0.60 m2 / 6.46 ft2
Fuel energy density (Wh/US gal.) [5]: - or -
Engine efficiency [6]: 0.35
Drivetrain efficiency: 0.95
One should try with the actual frontal area of the Golf.
What's the required Cd bump ?
Old 09-23-2013, 04:30 PM   #8 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
AFAIK the European 1.6 L TDi version will do close to that target ...
Old 09-23-2013, 05:23 PM   #9 (permalink)
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
Do modern engines have that high efficiencies at medium load ?
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
Old 09-30-2013, 05:51 PM   #10 (permalink)
widgets
CFD: OpenFOAM
Current CAD Model:
VW has already optimized everything you see on the Golf.I'm pretty certain that the car's visible ' look' will have to change in order to achieve your goal.
