Old 04-11-2010, 04:55 PM   #1 (permalink)
PaulH
MPaulHolmes's Avatar
Open ReVolt assembly FAQs
This is where the Frequently asked questions will go for assembling the motor controller. Clyde has some helpful suggestions. Also, anyone that wants to offer their advice, feel free to add it here too.
kits and boards
Old 05-30-2010, 09:51 AM   #2 (permalink)
How to attach lexan end covers.
Hi Paul, great idea to start this thread. I will be first to post my tip.
I pondered for a while on the best way to fix on the Lexan end covers to the Cougar controller kit. Finally came up with the solution of bending the ends of the Lexan so I could screw it to the sides of the cover. See attached pictures. I also used some instant gasket to seal the enclosure from moisture. On the end that has the B+ and B- bars I only used 3 screws, as the fourth one was going to be very close to the capacitors. To bend the Lexan was very easy for me, I let someone else do that! The local high school did that little job with their plastic bender.
Greg
ID:	6094   Click image for larger version
Old 05-30-2010, 10:02 AM   #3 (permalink)
PaulH
Holy mackerel that turned out nice! I didn't know you could bend lexan! What are those white things that keep the cables fastened to the green board? That looks like another very nice improvement.
kits and boards
Old 05-30-2010, 10:53 AM   #4 (permalink)
The white things are self adhesive cable holders/clips. I got mine from one of my automotive parts suppliers, but you might find something similar at radio shack. Or you could use instant gasket to glue the wires in a few spots to keep them from moving around, not as pretty, but cheaper.
The plastic bender is basically just a long wire/filament that heats up, and a arm to bend the plastic over. It heats the plastic until it is soft and then you bend it. Might get the same results with a heat gun, a vice and a piece of wood to bend the hot plastic. Practice on some scraps first to get the technique.
Greg
Old 05-23-2015, 07:12 PM   #5 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
I don't know if these questions are 'frequently asked' - but I asked them so as I get them answered, I'll post them.
first one
- which version of the Microchip IDE does Paul use?
Answer - 8.83
Old 05-26-2015, 10:16 AM   #6 (permalink)
What settings do I use for Hyperterm?
The settings are 19,200 baud, no parity, 8 data bits and 1 stop bit.
BMS for open revolt MPaulHolmes Open ReVolt: open source DC motor controller 25 07-06-2011 06:53 PM
Open ReVolt T-shirts bennelson Open ReVolt: open source DC motor controller 14 11-20-2010 12:28 PM
Open ReVolt - Pre build controller Nick Nameless Fossil Fuel Free 9 12-11-2009 11:45 AM
Revolt Open Source DC Controller Beta Testing jyanof Fossil Fuel Free 18 08-04-2009 11:43 AM
Open ReVolt as Charger wjdennis Fossil Fuel Free 8 06-24-2009 01:49 PM
