Old 09-03-2010, 04:53 AM   #1 (permalink)
Fizz - '06 Skoda Fabia Combi
90 day: 56.62 mpg (US)
outside air temperature and mpg
I have been logging the fuel economy and outside air temperature for a month or so; and thought I'd try to make sense of it. There's a nice trend, a linear fit gives mpg = (0.4*temperature) +70. Nice mix of imperial mpg and degrees centigrade - that's just what we use in the UK!
I found some figures for the "dynamic viscosity" of air and so compared figures for 10 degrees C and 20 degrees C.
Air - Absolute and Kinematic Viscosity
The effect on economy is 6% (78.5 and 74mpg (imp) at 20C and 10C respectively) ... and the viscosity changes by 5.3% (3.44 and 3.5).
Convincing - provided I've chosen the right type of viscosity...
Old 09-03-2010, 09:17 AM   #2 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
The benefits are more than just aero. There's faster warmup times, warmer tires, hotter air charge, and less frequent rain.
It is not necessary to concern yourself with viscosity. Aerodynamic drag varies linearly with air density. Without a datalogger, it's difficult to know how much energy you spend overcoming aerodynamic drag, versus inertia and rolling resistance, but you can use the Tools -> Calculator link at the top of the page to concoct an estimate for steady-state driving (zero inertial loads).
Old 09-03-2010, 10:05 AM   #3 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I concur that there is a linear relationship between temperature and mpg. Here are my results. This is 3 years of daily commuting, so it's as consistent as the real world can be. mpg is averaged at each point.
Old 09-05-2010, 08:36 PM   #4 (permalink)
...beats walking...
...FWIW, I have 8-months worth of AM (to work) and PM (to home) mpg-vs-temperature data showing similar results.
...there's a definite trendline difference:
• AM is cooler with slightly less traffic (at 0600 AM).
• PM is hotter with more traffic (at 1700-1800 PM).
...overall altitude difference is 220-feet over 26.2 miles, all freeway at 65 mph.
Old 09-06-2010, 03:12 AM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
ecoxantia -
I agree that IAT is an important component of MPG. Here is what I found :
ElmScan + Customized Scantool Software = data logging!
http://ecomodder.com/forum/187883-post20.html
Ok, I now have a workable formula, thanks to post #9 :
Calculating MPG from VSS and MAF from OBD2 - MP3Car.com
... For the record, the first "one-line" MPG formula above, taken from my Circuit Cellar article, is off by 100! The "4.54" should in fact be "454". The correct formula is:
MPG = (14.7 * 6.17 * 454 * VSS * 0.621371) / (3600 * MAF / 100)
MPG = 710.7 * VSS / MAF
Note that OBD-II VSS reading is in kilometers/hour and MAF reading is grams/sec times 100.
This formula works very well in a modern automobile because the engine computer spends almost 100% of its time managing the fuel-air-ratio to 14.7, which it can do very well because of the "closed loop" feedback from the O2 sensor(s).
In fact, the accuracy of this method has been proven in literally tens of thousands of gasoline-powered vehicles. Accuracy within a few percent is typical, often limited by the accuracy of the vehicle speed reading (i.e., VSS).
As for other ways of doing this, especially if you don't have a MAF sensor, by knowing the displacement of the engine, and after a simple "calibration" using fuel tank "fill-up" data to find the only unknown, namely the "volumetric efficiency" (VE) of the engine, MAF can be calculated from RPM, MAP and IAT. With VE, one can use the following formulas to calculate a synthetic "mass air-flow" (MAF) in grams per second, all without a MAF sensor, using the "Ideal Gas Law", as follows:
IMAP = RPM * MAP / IAT
MAF = (IMAP/120)*(VE/100)*(ED)*(MM)/(R)
where manifold absolute pressure (MAP) is in kPa, intake air temp (IAT) is in degrees Kelvin, R is 8.314 J/°K/mole and the average molecular mass of air (MM) is 28.97 g/mole. Note that, in the above formula, the volumetric efficiency of the (4-cycle!) engine is measured in percent and the engine displacement (ED) is in liters.
The VE of my 1999 7.4L Chevy Suburban is about 65%. Smaller, higher performance engines can have VE's of 85% or higher.
CarloSW2
American Solar Energy Society
Old 11-10-2012, 11:07 AM   #6 (permalink)
I know this was from a while ago, but would you be able to post the data for your graph, in a spreadsheet or equivalent?
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Scion xA aero mods NeilBlanchard Aerodynamics 521 04-20-2015 10:34 PM
Lower Air Dam Zerohour Aerodynamics 2 07-28-2010 09:04 PM
Effect of ambient temperature on fuel tank volume hummingbird Hypermiling / EcoDriver's Ed 5 01-04-2009 10:28 PM
OEM Air Injection, Yay or nay? Dane-ger EcoModding Central 11 01-14-2008 10:05 AM
