Overheating problem.
I'm going to make a dedicated overheating thread as I need help. I don't know what to do at this point.
Things I have tried: Coolant flush. Thermostat replacement. Block test (came up fine). I'm out of ideas. The coolant flush made my situation worse. I use to be able to put around town all day with no problems at all, and now just going to my friends house, which I have done a dozen times in the insight, it overheated. |
Who did the block test? Sometime they wont show up and then all of the sudden it shows up bad. I had a cobra like that.
Did you bleed the cooling system after the flush-thermostat? I posted in the other thread I thought it was the radiator. A radiator shop can test it for hot spots in the radiator.
regards mech |
My radiator was full of dirt and road dust, kept overheating on hill climbs. Try getting a car wash spray up close. Oh yeah I had tried everything also... I felt SO stupid!
new radiator
Does the heater work? If it doesn't its the water pump. Is the fan coming on? If the top hose from the radiator is hot you can know the thermostat is good.
This is the one I got, on a bid for 55.99, however you will need a different one for the insight.
I should take a photo of the old one before tossing it in the trash. |
