EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Oxygen Sensor Brands (https://ecomodder.com/forum/showthread.php/oxygen-sensor-brands-8076.html)
Southcross 04-24-2009 12:41 PM
I've searched... and every "Brand" says their product is superior to "other brands"
seriously... If my choices were Denso, Bosch, or NGK/NTK... and lets say they were the same price, same "universal" wiring... is there a "better" sensor for my buck?
SVOboy 04-24-2009 12:48 PM
All I know is that for lean-burn-using Hondas the Bosch sensors just won't work because they aren't made precise enough for the rest of the equipment. :p
Daox 04-24-2009 12:48 PM
At that point I'd go with whatever one is in stock. :) I really don't think it matters.
Southcross 04-24-2009 01:12 PM
thats what I'm thinking.... I'm thinking of going "which ever is least detrimental to my pocketbook"... LOL
I'm just currious if someone out there would say "ya, I had tried two different XXXX and YYYY brands and found that YYYY did ZZZZ"
cfg83 04-24-2009 01:20 PM
SVOboy -
I've heard the same. For my Saturn, I should have gotten the OEM Denso, but I got a universal Bosch. Maybe once a month I throw a code P0410 (secondary injection system failure/error). But I know from research that this is because the Bosch doesn't respond fast enough during startup testing. I just clear the error and ignore it, but it is annoying.
Unless you have definitive proof about brand "X", I would go with the OEM brand.
CarloSW2
Southcross 04-24-2009 01:30 PM
OEM brand is Bosch... but I'm "modifying" my setup for better cold FE. You would have to know the caveats of single wire vs multi-wire (heated) O2s. a Heated O2 may improve my FE allowing me to set the ECU to Closed Loop sooner
anywaysies... I'm even contemplating going "Cheap eBay", I think that's what I have in there now (single wire version):
eBay Motors: NEW BORG WARNER UNIVERSAL 3 WIRE OXYGEN SENSOR! (item 150271642570 end time May-11-09 22:10:13 PDT)
SVOboy 04-24-2009 01:47 PM
3 wire!? I've never heard of such a thing.
Daox 04-24-2009 01:55 PM
1 signal wire, grounds to the exhaust system. 2 wires for the heating element.
Southcross 04-24-2009 02:03 PM
1 - Signal only
2 - Signal, Shield
3 - Signal, Heat & Ground
4 - Signal, Shield, Heat & Ground
5 - typically wideband (don't know the pinout off the top of my head)
cfg83 04-24-2009 03:25 PM
Southcross -
I've also considered that and should probably do it. My post-cat is a heated 4-wire sensor.
My reason would be a little different. A while back RH77 reminded me that extensive use of EOC (engine off coasting) can cool the 1-wire 02 sensor and push you more into open-loop conditions. One that stays heated would be immune to EOC.
CarloSW2
