P&G freeway tested ABAB +14% FE
Actually the test was B-A-B-A if A is always supposed to be an “unmodded” run.
PURPOSE To see if I can do a standard P&G technique I call “GLEN” (Glide, Load, Engine-on, Neutral) on the freeway for significant FE benefits, preferably convincingly beyond possible “noise” of 1-3%. I have a 5.7 mile uphill freeway leg on my regular commute that I cannot route around with practicality or with sufficiently beneficial FE effects to justify the extra distances. Typically, I have scored low/mid 40s on this stretch by driving slower than is legal. Even then, this leg still brings down my averages. If I had a good solution, I could bring my averages up and not risk a ticket for too slow driving. METHOD Simple. Same time of day with roughly similar temps day-by-day over a one week period. Wind quite regular (absent) day to day. Drive one day with hypermiling, then the next day without, repeat until I have six runs minimum. The P&G technique used an acceleration arc from 55mph-65mph at 80% load. I then coast down to 55 again, seeking a 60mph average speed during the run. Up the steepest hills, I ranged from 55-60mph in the acceleration arc seeking a 57.5mph average. When doing the straight driving runs, I did my best to hold a steady 60mph, which was very tough in hilly terrain. Climbing the steepest hills I reduced speed to about 57.5. I never used EOC or any other hypermile method, such as driving in the slip-stream. RESULTS “A” = with P&G and “B” = without P&G A – 51.2mpg; ave 59.8mph.* B – 45.0mpg; 58.8 ave mph. A – 54.9mpg; ave 57.1mph. B – 47.7mpg; 58.1mph. A – 54.5mpg; 59.0mph. B – 44.9mpg; 58.9mph. *I forgot the exact mph number at the close of the run but this is close to correct. “A” averages = 53.53mpg @ 58.63mph “B” averages = 45.87mpg @ 58.60mph “A” is 7.66mpg HIGHER than “B” or 14.31% better. Random confirmation is suggested possibly by a 22 mile run I took the other day on the freeway, using this GLEN P&G method. I got 63.4mpg at nearly 60mph. Under normal conditions a month ago I could have seen maybe 52mpg on that run. Maybe only 49. |
Thank you, this is very helpful.
Is the whole course uphill? What is a typical glide time between pulses? |
Very nice results.
Thanks for testing this. I already knew P&G gives great results, but you put it into numbers.
Just to clarify, engine is on the whole time, right? Also how did you measure engine load, is it a scangauge function?
Seems like P&G is a lot of work, but if you practice enough it may just become habitual. Thank you for the results! |
When referred to on ecomodder, Pulse & Glide is traditionally without the engine running during the glide part. So California98Civic uses GLEN to differentiate his engine-on technique. |
Glide, Load, Engine On, Neutral?
Pulse & Glide = Get the car up to speed, and glide to a lower speed, and then accelerate again. I would Glide with the car in the highest gear, unless I was looking to build momentum, in which case, I would glide in Neutral. Pulse - I would pulse up to the speed limit. Can someone explain for me what Glide, Load, Engine On, Neutral is exactly? How does this work up hill - if you glide uphill, you'll lose momentum and have to get it back - and in many hills that momentum is gone as soon as you get it? Ahh: Found this: http://ecomodder.com/forum/showthrea...tml#post248966 Still, how does that work on hills exactly? |
The only difference is he is leaving the engine running instead of shutting it off during the glide. You could use PNG-on and PNG-off to differentiate. Many AT equipped cars should not be coasted with the engine off as it can damage many transmissions. Hope that helps you understand. regards Mech |
I was trying pulse and glide today on the freeway, I'd accelerate to 105kM/hr, and stick it in neutral leaving the engine on (at those speeds I think engine off coasting is disturbing), it doesn't take long for it to drop to 90kM/hr, and then I need to get back up to 105.
That's what I thought a Pulse and glide cycle was - if so, what am I doing wrong as surely, you aren't sitting there on the clutch every 15 seconds engaging gears (or in EOC, starting the engine)? |
