Old 06-19-2009, 07:29 PM   #1 (permalink)
Yaris - '07 Toyota Yaris Liftback
Pass Gas Slowly
Is is really true that filling up slowly gives you more gasoline because doing it at the high rate makes foam, which means that there is more air mixed in with your gas?
Old 06-19-2009, 07:36 PM   #2 (permalink)
Matt Herring's Avatar
Bone's 2010 Prius - '10 Toyota Prius Black
90 day: 56.78 mpg (US)
No
Old 06-19-2009, 07:47 PM   #3 (permalink)
robbiewt's Avatar
Yaris? - '08 Toyota Yaris LB
90 day: 41.87 mpg (US)
Send a message via AIM to robbiewt
No. Think about blowing bubbles in milk versus water. Bubbles in gasoline would go away too quickly to cause foam.
Old 06-19-2009, 07:58 PM   #4 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I have no idea, but thanks for the laugh with the clever title
Filling up at a higher rate causes the fuel to splash, which sometimes trips the sensor and shuts the pump off.
( Pull my finger )
Old 06-19-2009, 08:08 PM   #5 (permalink)
Vibe - '07 Pontiac Vibe
90 day: 47.11 mpg (US)
No you will not get air mixed in your gas.
Like robbiewt said, it's more like blowing bubbles in watter, the bubbles will NOT last long.
but... as your filling the air that is in the tank needs to come out as the gas takes up the space. the air rushing out faster due to a fast fill can "Some times" in "Some cars" can cause some gas to get splashed back onto the fill nozzle. the pump will shut off thinking fuel is now up to the nozzle and shut off to prevent an over flow.
in the past I have had cars that if I did not place the nozzle in the fill tube at the right angle the air would catch some of the gas and shut off the pump to soon.
at some point you will have a pump shut off to soon and it's most always due to air rushing out.
to avoid that and get a fill to a consistent point each time I pump slow. less splashing = more consistent fill point = better ability to accurately calculate my FE.
Old 06-19-2009, 10:18 PM   #6 (permalink)
Thanks! It's bean good learning
Old 06-19-2009, 10:46 PM   #7 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I've always pumped at the first auto-click in the handle, only to prevent loss of fuel from splashing and overflow.
The actual issue with pumping quickly (whether it's true or not, I suspect not) is not foaming, it's vaporization. The idea is that the faster you pump your gas, the more quickly it vaporizes, and the more of it you lose due to evaporation.
The idea is probably somewhat correct, but the time differential sets it off - If you take longer to pump, even though you're creating less vaporizing turbulence, you're giving the fuel more time to vent into open air.
If you pump faster, you're creating more fuel turbulence, which might vaporize more fuel, but you're giving the bulk of the fuel less air-time to vent.
It's probably a wash.
The other issue is that fuel pumps are certified with a margin of error, maybe +/- 1%... the pump is more likely to "break even" at a slower speed.
When you pump from a preset, most pumps now slow down when you get within about 1/2 gallon of that preset amount, so they don't cut off too soon or go over. Keeps you closer to being "on the dot".
Old 06-20-2009, 11:13 AM   #8 (permalink)
Just avoid the problem entirely. My car has a 10-gallon tank. If I put the nozzle on its slowest setting, that gives me just enough time to wash the windows while it fills :-)
Old 06-20-2009, 11:39 AM   #9 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
I always thought there was a vapor catch in the pump somewhere and it is designed to catch any vapor that may have come from the giant tank underground and recirculate it back into the tank, so that you don't get this bubble of air/vapor into your tank and have the pump count it as gas. I've noticed that I do get these bubbles out the nozzle when I pump at full speeds, so I put it on the lowest setting to allow it to trap all those vapors and get me more gas.
Plus, I get more time to get those bugs off the windshield!
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 06-20-2009, 08:27 PM   #10 (permalink)
I think there is a vapor filter in the tank, before the pump, but I can't verify that.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Article: Crude oil is getting cheaper — so why isn't gas? Frank Lee The Lounge 20 07-14-2010 01:06 AM
Hole in gas tank mrmad EcoModding Central 5 03-18-2009 04:33 PM
What's your best bet for an automatic? Crono EcoModding Central 16 10-22-2008 01:14 PM
News: Canadian gas prices may pass $1.30/L ($4.93/US gal) in months with $100 oil MetroMPG General Efficiency Discussion 5 01-04-2008 02:08 PM
