Old 12-01-2009, 04:03 PM   #111 (permalink)
PaulH
MPaulHolmes's Avatar
Good idea Jack! That would be bad. The micro-controller would never normally allow it, so it would have had to be something really bad (or coding mistake hehe). The microcontroller has it's own fault pin that does to the pwm outputs whatever you want it to do under a fault condition. Maybe if we assume the microcontroller craps out and the High and low are both stuck high for some reason, maybe a fast blow fuse? I would hope it would be a rare enough situation. Do they make fuses that could blow before the destruction of the igbts?
kits and boards
Old 12-01-2009, 04:12 PM   #112 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
Paul, PM sent..........
Old 12-01-2009, 04:15 PM   #113 (permalink)
jackbauer's Avatar
There are so called semiconductor protection fuses but i wouldn't bother. I only suggested it as back in the day i used to design hf ballasts for fluorescent lamps that used a push - pull mosfet setup and the most common failure was both devices turning on at the same time. I designed one with additional circuits that prevented this failure but the bean counters deemed it too expensive and made me remove the parts as it was cheaper to let a percentage of the ballasts blow then solve the problem! As the igbts are the most expensive parts it makes sense to protect them.
Old 12-01-2009, 05:00 PM   #114 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Block diagram
Being that lately I have enough spare time, I did some research on the basics of the AC motor controller and found on the PIC website something very interesting, a complete block diagram and some schematic of the AC controller final stage, not very complex and as you can see, the IGTBs are paired for each AC leg with out hardware (fuse) protection. I imagine that if it will be an inrush load above the software parameters, the PFC based power supply will cease operation protecting the final stage devices. Also note the implementation of the "BRAKE Chopper" for recapture of Regen back to the main raw supply.
Name:	AC Motor controller Block Diagram.jpg
Old 12-01-2009, 05:08 PM   #115 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
that power factor controller section is exactly the boost converter diagram on the prius as well.
Old 12-01-2009, 05:17 PM   #116 (permalink)
AC-DC enthusiast
mrbigh's Avatar
well, the basic of designs are almost the same, these are simple circuits though that need to be scalled up.
I have the same concept in my ManzanitaMicro PFC40 HM AC-DC/DC charger
Old 12-01-2009, 05:18 PM   #117 (permalink)
jackbauer's Avatar
Thats fine for an ac based supply. Now try that with 12 series connected odyssey agm batteries capable of sustaining 5000amps for 10 seconds
Old 12-01-2009, 05:19 PM   #118 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Now you are pushing the limits........
Old 12-02-2009, 06:01 AM   #119 (permalink)
jackbauer's Avatar
Didn't mean any offense with my last comment just wanted to point out that an ev inverter is a slightly different beast to an off the shelf vfd
what i'd like to see with this project is that it stays within the limits of what a person with a soldering iron and a few hand tools can build given a pre made pcb. I'd also like to see some smart design in there to prevent or at least minimise the probability of major failures. thats what i like about the dc controller. Its small , smart and easy to build. No crazy magnetics or stupid qfp smd parts etc. I built an atmega programmer in 30 minutes from some junk box parts.
Old 12-02-2009, 09:11 AM   #120 (permalink)
PaulH
Believe me, I'm not going to use surface mount components! I definitely want smart safety stuff built in too. At some point we should brainstorm all the horrible things that could happen, and try to figure out solutions that are as simple as possible that protect against those things. That will be fun!
kits and boards
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
