01-20-2013, 07:50 PM
#801 (permalink)
So, what's up!?!
Originally Posted by MPaulHolmes
We're moving in a few weeks, and I'll get working on it again once we're moved, and I get a workshop built. It shouldn't take too long.
Hello. How're you? How are things going?
01-20-2013, 10:18 PM
#802 (permalink)
Across from the DC controller thread. ^.^
Originally Posted by MPaulHolmes 01-17-2013, 12:56 PM
We just now got the 5 cubic yards of cement poured and leveled for the shop. PHEW!! That was a job. My wife was a huge help, dragging the 2x4 across to level it. Then I'll have a place to put the mill. Hurray!
01-20-2013, 11:18 PM
#803 (permalink)
PaulH
Two 4'x8' pieces are on the roof now out of a total of 8 of them. Then I need to figure out a door, but I can get the mill assembled now, once I figure out how to transport the 200 pound pieces. haha. Here's a picture:
The Following User Says Thank You to MPaulHolmes For This Useful Post:
01-23-2013, 09:24 PM
#804 (permalink)
AC-DC enthusiast
Well, it is a beginning !!!! congrats
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
01-30-2013, 01:49 PM
#805 (permalink)
PaulH
There was a catastrophic error in the AC code this whole time. It's a miracle that it was working at all. I had the following to ENABLE complementary output mode:
PWMCON1bits.PMOD1 = 1; //
PWMCON1bits.PMOD2 = 1;
PWMCON1bits.PMOD3 = 1; //
BUT, that was to DISABLE complementary output mode!! The deadtime wasn't working the whole time!
02-11-2013, 06:04 PM
#806 (permalink)
Hh
That is a bit of a futz xD
Poorly noted? Cus really unless its defined as a disable... 0 should be off sillies.
;p well, can't say its worse than my futzing = instead of == from time to time lol.
The Following User Says Thank You to roguethunder For This Useful Post:
02-24-2013, 06:20 PM
#807 (permalink)
Open Revolt AC
Hi Paul,
I just finished my EV. I have a 100Amps power stage used with an industrial VFD but the main board died after a few weeks. I found some PCBs and firmware for your AC controller. Would I be able to use it? If so can you supply PCB's?
Many Thanks
02-24-2013, 07:31 PM
#808 (permalink)
Control Boards
Originally Posted by cts_casemod
Hi Paul,
Many Thanks
I've been EAGERLY anticipating boards as well  . I have a FINE collection of industrial VFDs that could use a brain transplant.
Is there anything I can do (or perhaps someone else) to assist you, Paul?
02-24-2013, 08:03 PM
#809 (permalink)
Hi, are you refering to me or Paul?
I have the power section done with optocouplers for the IGBT, isolated power supplies, etc. I just need a suitable controller to drive this and I would like to try something different from a VFD CPU.
For those interested in my conversion search google for VW polo with industrial ac motor.
02-25-2013, 12:33 AM
#810 (permalink)
Oops
Sorry about that - quoted the last post instead of Paul's last post
I'll check out your build
