Old 01-25-2010, 08:46 AM   #1 (permalink)
Does dirty fuel filter cause bad economy?
Hello.
I have read on various forums that people have experienced better fuel economy after changing their fuel filters.
I'm wondering, how can a dirty fuel filter cause the vehicle to use more fuel?
wouldn't it use less?
Thanks.
Old 01-25-2010, 08:48 AM   #2 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
It can cause you to have worse, but most of the time it doesn't. (at least in my case)
Old 01-25-2010, 09:04 AM   #3 (permalink)
Thanks,
I'm wondering though, what is the technical explanation behind it causing bad fuel economy.
Old 01-25-2010, 09:39 AM   #4 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
If the filter is clogged, it won't run. If it's restricted, it simply makes the pump work harder.
GeoMetroforum.com - got mpg?
Old 01-25-2010, 04:19 PM   #5 (permalink)
Originally Posted by Z2TT View Post
Hello.
Thanks.
Z2TT,
A dirty fuel filter makes no difference to economy but it usually restricts the upper rev limit simply due to lack of flow.
Totally blocked the filter simply stops the engine since fuel can't get through.
Pete.
Old 01-25-2010, 04:35 PM   #6 (permalink)
Mater - '98 Dodge 3500 Dually
Wilber - '99 Toyota Corolla LX
Minyatta - '93 Mazda Miata MX-5
By trying to keep the engine running, the natural impulse is to add more throttle. So to make up for the restriction we try to add more fuel by pumping the accel pedal. So for instance instead of having the engine cruise at let's say 1500 RPM we overcompensate & the result is a fluctuation in overall engine speed 1250 to 1750 to 1400 to 1600, just trying to keep a steady 1500.
Dave
Old 01-25-2010, 05:18 PM   #7 (permalink)
If only K&N made fuel filters- think of the power and economy!!!
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
Christ (01-26-2010), vtec-e (02-01-2010)
Old 01-26-2010, 08:18 AM   #8 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I thought the dirty air filter thing was from back when cars were carbureted. Doesn't a restriction in airflow act as a choke, making the engine run rich?
Old 01-26-2010, 08:48 AM   #9 (permalink)
Frank Lee, what is your reasoning behind the K&N fuel filter. I run a K&N air for my truck, I noticed a difference right away. Is it an ultra low restriction gas filter?
Dave
Old 01-26-2010, 09:10 AM   #10 (permalink)
...beats walking...
...DANGER, Will Robinson, DANGER!
...if you use both a K&N air filter and a K&N gas filter, you'll save so much gasoline that it will backup and overflow the gas tank capacity, causing hydrocarbon air pollution and a fire danger (wink,wink)!!!
The Following User Says Thank You to gone-ot For This Useful Post:
CoastRider (01-26-2010)
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
List of common mechanical problems that hurt fuel economy Andyman General Efficiency Discussion 14 01-04-2016 03:59 PM
start to play with IAT sensor on Mercedes E250D-Turbo 98' poisas EcoModding Central 6 10-07-2013 04:13 PM
Drive Like a Trucker for Great Fuel Economy SVOboy EcoModder Blog Discussion 12 08-18-2009 09:20 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
