Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 10-16-2011, 10:46 PM   #41 (permalink)
OK, you have had your rant. I've long wanted to build a pedal powered Mercedes C-111 based on the paper model printed in Motor Trend magazine from the early 70's. The weight and air drag are major drawbacks. A human powered/electric hybrid could be legal for speeds of less than 45 mph. Check your local laws. For cheap and easy a tandem trike with fairings could be build for less than $1000 USD.
Old 10-17-2011, 05:52 AM   #42 (permalink)
IamIan's Avatar
Originally Posted by BarelyAWake View Post
That pedal car is great!
Interestingly, there may be some legal problems in the states however as they frown on four wheels w/pedal power for some reason (some regional variance)... two, no problem. Three? Yer good to go. Four? Nope - yer an evil lawbreaker.
Why? I've no idea lol
Is there some reason the vehicle needs to have 4 wheels? ... there are millions of vehicles on the roads that do not.
Old 10-18-2011, 12:29 AM   #43 (permalink)
Usually the problem has to due to passing slow moving vehicles on narrow two lane roads. If the pedal car or velomobile is narrow enough then a car can pass without changing lanes. If your friend does not want to look at your back all day, try mounting the seats and crank so that the knees of the passenger are next to the hips of the driver. This may allow you to move the seats 3-4 inches closer and getting under the 1 meter width.
Old 10-25-2011, 02:44 AM   #44 (permalink)
BarelyAWake's Avatar
As in some states there are no width limitations for bikes or trikes, yet as you're still not allowed four wheels I can only conclude the "concern" is regarding what they view as unregistered & uninsured cars, pedal powered or otherwise...
Laws regarding such rarely incorporate what we'd consider logic *shrug*
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Update (with video!): Pedal powered Buick driver beats court charge! MetroMPG Alternative Transportation 12 01-13-2014 03:37 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Active grill block idea holypaulie Aerodynamics 17 10-13-2008 09:31 AM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
