EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   Peugeot 206 1.4 HDi (https://ecomodder.com/forum/showthread.php/peugeot-206-1-4-hdi-32364.html)
Sjoegerd 07-13-2015 03:51 PM
Peugeot 206 1.4 HDi
Hi all!
Don't know if I put it in the right subforum, but I bought a "new" car!
It was time for me to switch to a car which is more suitable to make more kilometers each year. The Peugeot 106 served me well, but with my calculations, the 206 would save me a lot of money.
I have no numbers about my fuel consumption yet, but I make enough kilometers to get back at that soon ;)
Greetings,
Sjoegerd
Daox 07-13-2015 04:14 PM
Congrats on the new ride.
What is the 206 rated mpg wise for compared to the 106?
Sjoegerd 07-13-2015 04:29 PM
The factory specifications of the 206 are: 54,8 mpg US
The factory specifications of the 106 are: 36,7 mpg US
I used to do around 40 mpg with the 106. Beside that, diesel is 30-40 cents per liter cheaper than petrol but the roadtax is much higher.
Sjoegerd 07-20-2015 03:24 PM
Finally made a photo of the car:
https://scontent-ams3-1.xx.fbcdn.net...82&oe=564E12F2
After a half tank I filled it up. Got to 20 km/L, that is about 47 MPG (US). I wasn't even trying so I know I can do better :)
Sjoegerd 12-28-2015 02:21 PM
Fuel usage after about 14.000 km is 19,35 KM/L, and still not trying :rolleyes:.. But it is still pretty good. Most of the time I drive between 80 and 110 km/h with constant speed. Love driving the car! :D
Piwoslaw 12-28-2015 02:52 PM
I understand that you are trying to get a baseline to improve on?
Because it is definitely not due to a lack of good tips here...
When you finally get around to ecomodding, how far do you want to go? Bumping tire pressure, grille block, engine insulation, Kammback, ???
Sjoegerd 12-28-2015 03:26 PM
It really is setting a accurate baseline. I know the car is capable to be more fuel efficient without even doing modifications.
I hope to build a grill block in 2016. I have a nice idea that will smooth out the front bumper. I will not go to a Kammback, maybe smoothen the underside of the car out.
First it will go for the yearly mandatory test in January. I hope it will pass without a lot of investment.
Piwoslaw 12-28-2015 11:55 PM
Does your P206 already have an engine undertray? Iirc, these were stock only on the diesel-engined models, while the petrols had none.
Sjoegerd 12-29-2015 02:07 PM
Yes it already have an engine undertray. But I saw a new type Peugeot 308, which has a much smoother bellypan with multiple plastic undertrays. Maybe it is possible to make something like that.
cRiPpLe_rOoStEr 12-29-2015 08:12 PM
Is a vegetable oil conversion (such as those Elsbett kits) a viable option to you?
