Old 09-18-2010, 02:05 PM   #1 (permalink)
Supercharging for economy?
I was reading a review for the new version of the car I have, the Nissan Micra. The new car is rated at 56.5mpg, which is fairly impressive in itself, however next year a SUPERCHARGED version of the same engine in the same car is set to come in with 20% more power AND more economy (71mpg) any one have any ideas on how this could be working? It's against my understanding of how superchargers work.. i.e. trading more fuel for more power in a smaller space.
Link to review: Nissan Micra Hatchback Car Review - Auto Trader UK
58.35 MPG last tank = 127% EPA
49.23 MPG 9 tank average = 107% EPA
66.11 MPG best tank.
Old 09-18-2010, 05:59 PM   #2 (permalink)
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
A supercharger is belt driven off an engines crank pulley, such that its rotation depends on engine rpm. There are some that have a clutch operated pulley system that allows the supercharger to spin up to a desired speed and hold there throughout the rpm range; max boost instantly, or whenever you set it up to be.
"Forced induction" essentially increases the volumetric efficiency of an engine to that over the limits of natural aspiration. In a NA application, the VE of an engine varies on throttle position and rpm. In a FI application, you can have a VE of 100% (that is, 0psi of boost) at any throttle position and any rpm, if the turbo/supercharger is setup up to do so. This is possible because more air is being forced into your motor than the motor alone could suck in alone.
I used to have a 2000 Dodge Stratus Coupe with a mitsubishi 3.0L V6 engine. I extensively modified the car, adding a vortech v-1 s-trim supercharger, standalone computer, larger injectors, completely rebuilt motor, and much more. To make a long story short, having the supercharger on the car increased my cruising gas mileage about 10-15% compared to its stock NA form.
I sure do miss her. 550hp to the front wheels was very interesting:
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
Old 09-18-2010, 08:19 PM   #3 (permalink)
A friend of mine has talked a little about replacing the throttle assembly with a rotary compressor driven by an inverter motor. The idea is that boost pressure can be controlled electronically to get the most out of the fuel under heavy load. At light load, the compressor acts as a turbine to recover pumping losses. Combine that with a turboalternator (exhaust gas turbine driving a high speed alternator) and it should work better than a conventional turbocharger.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 09-19-2010, 10:18 AM   #4 (permalink)
@theycallmeebryan
How did the enormous white radome on top of the Stratos affect performance?
Old 09-19-2010, 05:24 PM   #5 (permalink)
...beats walking...
...probably no help, but the radar inside of it probably DID help detect approaching cop cars and speed traps (ha,ha)!
Old 09-19-2010, 05:29 PM   #6 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
VW and AUDI us a supercharger as part of the TwinCharger engines.
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 09-20-2010, 08:04 AM   #7 (permalink)
A few comparisons of supercharged vs NA reveal some figures:
Mini cooper (NA) 42mpg
Mini cooper S (SC) 32mpg (similar 1.6 Brazilian built 4-pot) Source: Parkers.co.uk
The mercedes range is the only one I can find with lots of supercharged cars, and provides lots of interesting info:
Mercedes C180 (NA) 32MPG
Mercedes C180 Kompressor (SC) 37mpg
Mercedes C230 (NA: 163bhp) 30mpg
Mercedes C230 Kompressor (SC: 192bhp) 34mpg
Mercedes C230 (NA: 201bhp) 30mpg
All I've done here is confused myself!!
Old 09-20-2010, 08:26 AM   #8 (permalink)
This has been talked about before, but more so with turbocharging since turbos actually use more of the waste heat. Superchargers steal power directly from the engine to make more power. Anyway, the conclusion has always been the main benefit of supercharging/turbocharging is the ability to now downsize your engine since it is producing more power. If you don't downsize the engine the best you can hope for is the same mileage which is highly unlikely.
Old 09-20-2010, 08:36 AM   #9 (permalink)
That's what I'd always thought, although in new car's it's going to be more complex. A different tourque curve may lead to them fitting taller gears.
They mentioned on Top Gear that the supercharger on a McLaren Mercedes SLR "costs" 120+bhp just to run. That can't be good for FE.
Old 09-20-2010, 09:11 AM   #10 (permalink)
That may may be true, but the benefit is coming from the gearing, not the supercharger at that point.
