Pictures of my wheel skirts
2 Attachment(s)
They maybe are not pretty, but functional :)
holypaulie -
I like 'em. Silver painted cars and aluminum mods go well together. Being devil's advocate for the moment; on the front tires, if you were doing a Left U-Turn and hit a pothole, would you risk lacerating the front driver's-side tire? I ask because it looks sharp and metallic. It looks like a cut edge rather than a round/folded edge. CarloSW2 |
Hi,
Some more good work -- I like the grill and the radiator duct mods from the other thread, too. Did you add these and test them on their own, or add them all at once? What kind of mileage are you getting? Now, you just need to add some smooth wheel covers? |
They look better than mine! I like the front deflectors - look pretty sharp.
I was thinking about taping my alloy rims with aluminum tape. What do you think about that? |
Everyone is keep askin' me what is whole thing about, because they never seen anything like that.
holypaulie -
CarloSW2 |
Hi,
I think that aluminum/foil tape on the wheels can work. I did a partial job on my front wheels, and it may have helped -- but the smooth wheel covers has helped, for sure. I've been wanting to do front wheel skirts just like what you've done. And I want to do a more permanent grill block, that forms a more curved "nose" on my xA. |
So the wheel skirts have had a noticeable affect on FE and drag? Have you felt longer glides?
I have a Civic too, but it's an 8thgen sedan. Thinking about getting aeromods. In the spring (or, the next time I drive to/from school and it isn't freezing), I'm going to do a big 260 mile test with masking tape mods to make my hubcaps smooth, block the top grille, maybe skirts or miniskirts, and covering up some seams that look obtrusive. Or is that dumb, to use masking tape (which is, after all, designed to come off...)...I just want something very temporary and cheap. Also, could you explain how you mounted the rear skirts? |
On the first place I would put grill block with bellypan and front wheels deflector, then second wheel skirts with eliminated parachute effect, last smooth hubcaps. If you want something temporary and cheap masking tape is perfect. You can also try weight reduction if you need better acceleration. I've cut 1" wide, 1/16" thick and 2" long metal strips and bent them 90* on vise. Next drilled mounts directly to inner edge of wheel well with self-tapping screws. Painted and sealed with waterproof glue. Finally screwed in skirt again with self-tapping screws. |
Nice work, holypaulie. The radiator venting is impressive too.
More information about smooth wheel covers (including tape experiments in a wind tunnel) in this thread: http://ecomodder.com/forum/showthrea...-6-a-4368.html |
nice upgrade!
