Old 06-10-2008, 09:05 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Scion xA aero mods
Greetings,
I've been testing some aero mods -- using good old duct tape, for the moment.
Simple stuff so far, and it seems to be quite effective: my best tankful average last year was 41.8mpg, and with some improved driving techniques, I got 43.5mpg on a tank. After covering the upper grill, I've got a new best of 45.5mpg. Then I covered the fog light recesses, and it's looking much better still!
The 45.5mpg tank was ~239 miles at the half tank -- and this tank is sitting at ~275 miles at a half a tank left! So if I do only 200 miles on the second half tank, that could be ~47.5mpg! Heck -- I might be on course to do almost 50mpg?! Incredible, if that's how it turns out.
[Edit: I ended up with 46.4mpg, partly because my last commute up Route 3/93/95 and on Route 117 was pretty clogged with stop and go traffic...]
So, I'm going to be trying to construct an even sleeker nose -- if I can form some planes to kick the air flow out and around the front wheels, and keep the required cooling (today was very hot -- near 100F and it worked fine!), then I could be exceeding what I thought this car was capable of.
Last edited by NeilBlanchard; 06-15-2008 at 11:29 PM.. Reason: corrected mileage numbers -- I forgot my current best. D'oh!
Old 06-10-2008, 09:29 PM   #2 (permalink)
Polymer - '89 Civic Hatch Std 4 speed
Woodstock - '69 Midget 1275
Nekobus - '06 xB
The truth will come out in 4-5 tanks.
My mileage swings up and down by almost 10mpg on each tank, depending on when the bloody pump shuts off the nozzle. I don't take the risk of topping off repeatedly like some. I do slow the pump down when I know it's nearing the top though - makes for a little more consistency.
I'm quite interested to see what sort of improvements you can make. I've got an xB and may be in the market for a replacement car for my aging civic.
Old 06-10-2008, 09:34 PM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Can't wait to hear what the next tank is Neil. Looks like its comming along well.
Thats some huge variance millenniumtree! My tanks in my Matrix vary about 3 mpg (40-43) and there are two different people driving it.
Old 06-10-2008, 09:34 PM   #4 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Neil: that's encouraging. A 1.7 mpg gain works out to a 3.9% increase.
I did a number of non-rigorous "A" (5 controls) - "B" (2 grille block) runs and saw an average 2.9% gain @ highway speeds.
Old 06-10-2008, 09:44 PM   #5 (permalink)
EcoModding Seige Tank
digitaldissent's Avatar
yarii - '07 Yaris 4dr (auto)
90 day: 41.37 mpg (US)
Bullet Bill - '07 Yaris 2dr hatch
90 day: 36.19 mpg (US)
looking good, I think I will just tape over my fog light spots like you for now.
I got a little bump with the upper grill block too, wonder if it will last
I am not trying to save the planet, just trying to hurt it a little less
Yaris build thread
what is... http://en.wikipedia.org/wiki/COINTELPRO
Old 06-10-2008, 09:56 PM   #6 (permalink)
Philthy
craggin' wagon - '01 Outback
I didn't see much improvement on my grill block but that could be for many reasons. One questions I have is this, is it better to block the upper grill or lower grill? I have a Subaru Outback with the lower grill blocked and the upper grill open. I chose to do the lower one cause it was a bigger opening but it may be at the stagnant point anyhow so the blocking the upper grill may be better for smoothing flow over the hood. any thoughts?
Old 06-10-2008, 10:05 PM   #7 (permalink)
CM400E - '81 CM400E
Thats the general consensus. If your going to block one, the upper helps more with aero.
Old 06-10-2008, 10:11 PM   #8 (permalink)
You're right on: all else being equal, better to block the upper opening and send air that's already above the stagnation point over/around the car where there's less drag. Feed air that's below the stagnation point through the radiator, since it was going to end up in the turbulence underneath the car anyway.
Old 06-10-2008, 10:20 PM   #9 (permalink)
Philthy
sweet, i'll have to try that. I think it will make for a prettier mod too.
Old 06-10-2008, 10:26 PM   #10 (permalink)
Josepha - '08 xD
Hi,
I blocked the upper one because it is flush (the lower one is recessed) and it helps the air flow up over the hood. Also, the standard upper grill is more closed than mine is, so I felt more confident going without the cooling air. And there is the slot just above the bumper, too.
It worked perfectly well today in very slow/stopped traffic on Route 128 with the temps in the upper 90's.
grille block
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/scion-xa-aero-mods-2969.html
Posted By For Type Date
Volkswagen brings 260-mpg XL1 Concept a step closer to reality - Autoblog Green This thread Refback 07-05-2011 03:29 AM
How bad do you want to get better mileage??? - Page 5 This thread Refback 06-10-2011 05:05 PM
Video Mirrors - "eyes forward" system - Page 2 - ApteraForum.com - Unofficial Aptera Car Forum This thread Refback 06-03-2011 05:52 PM
How much do Rear Spoilers hurt MPG? - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback 04-28-2011 02:02 PM
SPCR • View topic - Super Efficient Cars [very large pictures] This thread Refback 04-13-2011 05:50 PM
Volkswagen brings 260-mpg XL1 Concept a step closer to reality — Autoblog Green This thread Refback 01-26-2011 10:49 AM
Zombie Squad • View topic - Feul Efficiency in a BOV This thread Refback 01-23-2011 11:16 PM
Page 2: Quick weight reduction and slipperiness-- worth it? - Motor Trend The General Forum Forum This thread Refback 12-13-2010 06:47 PM
Neil Blanchard Designs: More ways for auto makers to build more efficient vehicles - Updated 29 June 2010! This thread Refback 11-26-2010 09:09 PM
Nissan Leaf snags 99 mpg rating on official EPA sticker — Autoblog Green This thread Refback 11-24-2010 04:20 PM
Will we ever replace the standard rear- and side-view mirror? - Autoblog Green This thread Refback 11-07-2010 09:13 AM
Neil Blanchard Designs: Aerodynamic modifications to save gasoline This thread Refback 10-10-2010 11:43 PM
Neil Blanchard Designs: "eyes forward" Video Mirrors on my xA This thread Refback 09-23-2010 04:09 AM
xA MPG Hypermiling Quest - Scionlife.com This thread Refback 08-20-2010 02:45 AM
SocialNetworkInc.com: Cloud Vision This thread Refback 08-14-2010 08:54 AM
How much do Rear Spoilers hurt MPG? - Corral.net : Ford Mustang Forums This thread Refback 08-02-2010 05:32 PM
Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 07-19-2010 05:58 AM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 05-20-2010 02:56 PM
3 posts tagged ?ecodriving? - NeilBlanchard?s Blog on Vox This thread Refback 04-27-2010 06:20 PM
More ways for auto makers to build more efficient vehicles - Updated 13 Apr 2010! - Vox This thread Refback 04-15-2010 07:32 PM
Ford creates suggestion box for consumers, what do you want? — Autoblog Green This thread Refback 04-14-2010 01:19 PM
3 posts tagged ?video mirrors? - NeilBlanchard?s Blog on Vox This thread Refback 04-12-2010 03:03 AM
6 posts from 2008 - NeilBlanchard?s Blog on Vox This thread Refback 04-08-2010 03:49 PM
EcoDriving & Other Vehicle Efficiency Improvements (Page 2) - Future Car Reports This thread Refback 03-28-2010 06:25 PM
silentpcreview.com | View topic - Super Efficient Cars [very large pictures] This thread Refback 03-26-2010 10:24 AM
Improving Vehicle Efficiencies -- A List! - Electric A!D This thread Refback 01-27-2010 05:23 PM
"eyes forward" Video Mirrors on my xA - Vox This thread Refback 01-25-2010 08:56 AM
How much do Rear Spoilers hurt MPG? - Corral Forums This thread Refback 01-07-2010 11:34 PM
5 posts tagged ?aerodynamic drag? - NeilBlanchard?s Blog on Vox This thread Refback 12-26-2009 12:13 PM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 12-24-2009 02:13 AM
12 posts from 2009 - NeilBlanchard?s Blog on Vox This thread Refback 11-30-2009 03:23 PM
Production Aptera 2e leaked again on forum — Autoblog Green This thread Refback 10-30-2009 01:09 AM
What if... the Aptera 2e had a EESU? - Page 6 - ApteraForum.com - Aptera Car Forum This thread Refback 10-09-2009 11:17 AM
Greenlings: Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 10-01-2009 11:58 PM
Ask AutoblogGreen: Do electric vehicles need front air intakes? — Autoblog Green This thread Refback 08-29-2009 10:37 AM
Posts (page 2) - NeilBlanchard’s Blog on Vox This thread Refback 08-23-2009 12:16 PM
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 72 01-05-2012 01:36 PM
Scion XA in PA goodblues Introductions 25 08-27-2010 09:49 AM
Aero mods on 06 civic c0da Aerodynamics 28 05-20-2009 04:17 PM
Planning Aero Mods Doofus McFancypants Aerodynamics 30 06-15-2008 07:03 PM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 07:44 PM
