01-04-2021, 04:32 AM
A very interesting theory about drag
This video came about after I sent a request to several top car aerodynamicists (ones I'd came into contact with through working on my book) about the relationship between pressures measured on the side of the car, and the base (ie wake) pressure.
My measurements show that pressures at the rear edges of cars don't always match wake pressures (although the match seems pretty good on squareback shapes). So what actually is the connection between (say) side pressures and base pressures? If we understand that more clearly, we (as amateurs) can then develop approaches to reduce base pressure and so drag.
Dr Adrian Gaylard (Jaguar Land Rover) came back with an intriguing response that I'd never thought of before. He referenced Hoerner's classic book on aero drag, linked to a more modern paper and put that all in the context of his own understandings.
This video looks at that particular theory - I may later do others on what the other aerodynamicists told me.
My gut feeling is that this theory helps explain some aspects of base pressure - as all the aerodynamicists told me, there is a lot going on, and so one theory is unlikely to explain everything!
It does, however, make sense in the context of the measurements I have made in the last month on cars as diverse as a Skoda Roomster squareback, W212 Mercedes notchback, Gen I Honda Insight fastback and Tesla Model 3 fastback.
The Following 2 Users Say Thank You to JulianEdgar For This Useful Post:
01-04-2021, 11:26 PM
Thick boundary layer -> less base drag (via less jet pump affect)
Can the affect also be measured as a pressure increase on the back of the car? Did you have sensors on the back of the Tesla?
And related... Same idea apply to vortex generators? That is, they upset/disturb the jet pump action?
01-04-2021, 11:30 PM
No I didn't think until afterwards that I should also have measured base pressure on the Tesla. But I can easily disturb side flow on another car and see if side pressures decrease and base pressures decrease.
Despite the claim often being made, I've never seen any evidence that vortex generators work in altering base pressure. They certainly can work in putting energy back into the boundary layer and causing better flow attachment around corners, but that's a completely different thing.
01-05-2021, 09:53 AM
Thank you for posting the video.
Is this thicker boundary layer air responsible for mitigating or jumping over the different angle between rear window glass and trunk on a saloon/sedan?
This intersection is usually accused of interrupting attached flow, however in wind tunnels with smoke the flow looks smooth, angle differences seem to disappear - especially with increased distance from surface.
Where are the greatest pressure differences measured at the rear of the car?
1. Between top and bottom
2. Between top and side
3. Between side and bottom
Only 4-planes of interaction on a rectangular section car/truck, correct?
I suspect the "Jet Pump" phenomena is greatest under the car where it is squeezed and partially contained by ground plane.
I have not read the PDF in the link below, but it could be related to this topic.
Review on Aerodynamic Drag Reduction of Vehicles
https://www.researchgate.net/figure/...fig1_330661575
01-05-2021, 10:03 AM
I also found this paper regarding side spoilers. Looks like they are able to CFD pressures off the surface, and these pressure zones have a shape to them.
The boundary layer(s) are also illustrated in a way I have not seen before.
Influence of Side Spoilers on the Aerodynamic Properties of a Sports Car
https://www.mdpi.com/1996-1073/12/24/4697/htm
Abstract
This paper discusses the capabilities of side spoilers to improve the aerodynamic properties of a sports car exposed to a non-zero yaw angle flow. In such conditions, the aerodynamic drag and lift both increase with the introduction of a side force and a yawing moment, which contribute to the decrease of the car’s handling properties and force the car to change its driving path. Elements mounted on the side of the car make it possible to obtain an asymmetric aerodynamic load distribution and generate additional forces that can be used to counter these effects. The performance of the side spoilers was analyzed at yaw angles ranging from 0° to 15° using the results of numerical calculations. It was established that the side spoilers made it possible to generate at low yaw angles aerodynamic forces that exceeded those caused by a crosswind.
01-05-2021, 06:12 PM
The first paper just looks like a grab-bag of everything they could find research on - ie a non analytical literature search.
The second paper, though, is quite fascinating - active spoilers located on the front bumper side and A pillar. But neither was good for drag, and their argument that the spoilers could help control the car in cross-winds overlooks the fact that the spoilers would have to be able to move extremely fast. (In the paper they get over that problem by talking about a constant crosswind - but that's not very real world.)
Re the boundary layer and:
No, in fact the thicker the boundary layer, the less likely air is to follow changes in shape. That's why vortex generators, that put moving flow energy back into the boundary layer, can cause better flow attachment around corners.
Re:
There is almost no tech lit available on this, and I haven't done that series of measurements. My guess is that the answer would be heavily dependent on the shape and underside smoothness of the car.
01-05-2021, 07:21 PM
My disappointment was that the digram you showed and ask us to imagine 3D showed the flow over and under the car but it was all about side pressures.
There is a silent minority at Ecomodder who hold that the air is standing still and it's the vehicle that is moving.
Which is to my point. If you have contact with Dr. A. Gaylard ask him this: All talk about boundary layer references free air. The underbody is a plenum with four open sides and two [relatively] moving walls. I know that when testing motor oil (analogizing from engine theory, I know) what they use is two concentric cylinders with an oil film between. The shear forces can tear oil molecules apart.
So the condition in the underbody should be shear forces instead of boundary layer. Or, I'm wrong. Whichever.
I have an idea for easy 3D diagrams, maybe I can prepare an example.
.Necessity is the mother of invention, but simplicity is it's favorite aunt --Amish proverb
01-05-2021, 07:28 PM
Because the pressures above and below the car depend on a lot of other factors besides boundary layer thickness, and so to introduce top / bottom would have caused confusion in terms of the overall point being made.
As I said in the video, I may cover the other theories of the influences on base pressure in further videos (and they would include, for example, trailing edge pressures on the upper surface that would in turn involve body shape, vortices, etc).
01-05-2021, 07:34 PM
#9 (permalink)
You are implying that the boundary layer under the car extends between the underbody and the road. (That is, it's the shear forces that are most germane.) This is not the case in any modern car that has a smooth underfloor. It may, however, be the case with old cars with rough underbodies that have a very low ride height.
I have bought multiple pitot tubes so that I can directly measure boundary layer thickness, but I doubt I'll be doing that under the car (too easy to lose them over a bump).
01-06-2021, 01:36 AM
#10 (permalink)
Okay, but I wasn't thinking about a rough underbody. Assume the underbody is as rough as the pavement.
There will be a gradient away from the underbody and the road, with some amount of turbulent mixing at the center. IIRC test show an optimal ride height [for a given design]. Normally assumed to be exposure of the tire faces?
I'm working on that graphic demo. Something presentable seems achievable, else it's not the good idea I'd thought.
Ablative extensions to the pitot tube?
