Old 05-08-2013, 04:01 AM   #11 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
You can always change your carburetor to FI with Megasquirt. It will be much easier to pass any smog test with it, and to get better FE
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 05-08-2013, 12:02 PM   #12 (permalink)
If I have to go to that extreme I'll do a swap. Based on a five minute search, I think the only way to get past smog with a Megasquirt system would be to hide it or pay off the smog tech.
I'm currently looking into using a PLX or Innovate wideband system, but I think I will need to chip the ECU to do this. I am researching now what that will entail.
This is unfortunately turning from what I had hoped to be a relatively easy rebuild to a pretty complex undertaking. And that only because CA smog.
Old 05-09-2013, 07:39 PM   #13 (permalink)
You may get more FE and put out less emissions, but it won't pass smog. It will show as "TAMPERED" and fail as a "GROSS POLLUTER", no matter how clean it runs.
-soD
1986, crx, oxygen
