Old 06-08-2017, 09:00 PM   #11 (permalink)
Primer is still paint!
ChopStix's Avatar
90 day: 32.46 mpg (US)
Originally Posted by ballo View Post
Yeah, I figured Chop's temperature swing would be much bigger than mine. It's very temperate here. Winds are fairly similar (low) and the suburban roads I drive are fairly sheltered from wind by trees and structures.
Yeah where I live we have giant temp swings. Peak Summer verse Peak Winter, we have 100 degrees (or more) difference.
Old 06-08-2017, 09:48 PM   #12 (permalink)
hatch - '05 Volkswagen Golf Mk.V
90 day: 33.42 mpg (US)
Is it possible my engine really doesn't have a PCV valve?
Perplexing response from VW, Sent in a parts order request:
"this vehicle does not have a PCV – if you are referring to the piece that the oil filler cap screws into, this is part of the rocker cover - $..."
I found pcv valves for the BGU engine in older cars, and equivalent year SEATs (06A 103 465D) which look superficially the same:
But the wall around the filler is much thinner, the X reinforcement doesn't match, there's no marked part number, and I see no breaks to allow vented air in.
If I trust the parts guy, my guess is they deleted the PCV valve on a revision, and kept the tube positions to route the breather to the intake pre-throttle.
Old 06-08-2017, 11:29 PM   #13 (permalink)
ScanGauge <3
ThermionicScott's Avatar
Brakes dragging?
Best tank (so far): 32 MPG
Old 06-26-2017, 04:12 AM   #14 (permalink)
I fixed the problem partially through driving style.
With the stuck EGR the car had much less power. I didn't think to recalibrate my foot once that was repaired. Local fuel economy improved ~1L/100km with much more sluggish acceleration, no impact on longer trips.
Now I'm chasing down a darn oil consumption problem. Again this'd be easier if I had a buggered PCV that I could blame things on.
If I need a piston ring set it's going to cost me something like $150, $200 timing belt due soon, and a better engine with lower mileage is under $300. Think I'll try running with some thicker oil and decide what to do from there.
Maybe I'll just get a smaller more reliable car...
