Old 10-07-2014, 03:38 PM   #1 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
poor results after timing belt change
I had the timing belt and water pump replaced at a shop, as the work seemed a bit beyond me. They replaced the spark plugs, wires, gaskets, thermostat, and adjusted the valves.
My initial impression is that the car doesn't accelerate up freeway on ramps as well from stops, that the gauge would go into open loop way too easily, and that the average mpg on trips is about 5 mpg lower than previous to the change. There is a long thin string of oil leaking from the long edge of the valve gasket, and slightly more leaking on the driver's side.
Could any of those things reduce mpg and, if so, what should I look for?
I want to check the spark plug gaps, but need to get an extension to reach them.
Old 10-07-2014, 03:59 PM   #2 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 39.31 mpg (US)
That sucks, and this is exactly the reason I do all of those items myself!
Sucks when that many things are replaced at the same time, too. Makes it harder to track down what the issue is. I'd take it right back to them and have them check timing, etc. . . . . until you're satisfied with it.
Once, long ago, I had a garage put new plugs on mine. It ran really crappy afterwards, and I wouldn't leave the shop until they fixed it. They found after about an hour of searching that the "mechanic" had bumped one of the plugs and closed the gap on it!
Good luck!
The Following User Says Thank You to cowmeat For This Useful Post:
j12piprius (10-08-2014)
Old 10-07-2014, 04:26 PM   #3 (permalink)
90 day: 35.79 mpg (US)
When I needed to do the timing belt on Bacon, someone told me that his mom could do it in six hours with her eyes closed. I do not know about that. I plan on doing it with Chorizo, just two thousand miles until it is supposed to happen.
I do not know what the shop did wrong, but the timing belt jumped a tooth after they replaced the timing belt. She actually ran perfectly for two weeks. I took it back and they claimed that it was not their fault, but fixed it for free out of the goodness of their hearts.
Good luck!
Old 10-07-2014, 04:35 PM   #4 (permalink)
cowmeat's Avatar
Maverick Hybrids
Mechanics drive me nuts, I just refuse to deal with them.
I admit, I jumped a tooth on the cam sprocket when I changed out Black Widow's timing belt about six months ago. As soon as I fired it up I said to myself "I bet I jumped a tooth", but I added a string of curse words into the sentence.
I drove it like that for a week until I couldn't stand the funkiness any longer, tore it back down the next weekend and sure enough, the cam sprocket was off one tooth.
However, I didn't try to convince myself it wasn't my fault!
If those scrubs had your timing off a tooth after they changed the timing belt, it was their fault! If they say the tensioner pulley blah, blah, etc. . . .then they should have replaced it in the first place! You paid them to fix your car, and if it runs worse now, it's definitely their fault
Old 10-07-2014, 07:26 PM   #5 (permalink)
What brake pedal?
digital rules's Avatar
Silver Streak-5M - '05 Toyota Corolla S
90 day: 42.41 mpg (US)
Keep in mind some of the drop in MPG may be be caused by the winter gas formulation. I am noticing about a 1-2 MPG drop since my last fill up.
Old 10-07-2014, 07:50 PM   #6 (permalink)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 21.74 mpg (US)
I second all of the opinions expressed here.
If you want something done correctly, you have to do it yourself. Nobody really cares if they do it correctly because it isn't their car, and they get paid by the job. They also don't care to fix something they messed up, because they've already been paid, and that takes up time they could be getting paid by someone else.
That said, take it back to the shop and have them make it right.
Old 10-07-2014, 10:35 PM   #7 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
It could be something as simple as a sensor not plugged in. But in any case, I would have them fix it.
And don't hesitate to get the BBB involved if it comes to that.
Old 10-08-2014, 01:30 AM   #8 (permalink)
What about me doing it? Have you seen my handiwork?!
Old 10-08-2014, 11:22 PM   #9 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
I was going to mention that, but you beat me to it. I experience the same thing every year between September and October.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
Old 10-14-2014, 04:19 PM   #10 (permalink)
Liberty Lover
j12piprius's Avatar
spark plug gaps
I finally got a 3/8" extension. The gaps were all .036 inches.
The manual recommends .04, and NKG recommends .044 for the plugs.
I set them at .044 to .045 inches. Should this make a difference?
