Old 10-10-2009, 10:28 PM   #1 (permalink)
Cycling more to drive les
White 'rolla - '05 Toyota Corolla LE
90 day: 44.39 mpg (US)
Send a message via AIM to Chalupa102
My new wheels may get better f/e
I've stated before in a prior thread that i use to think that the wheels that i had were lighter, but actually they weren't. I figured they might be robbing my fuel economy because they were pretty wide (205/50/17) and because of the rim design. On an all highway trip to pick up the new wheels today, i averaged 43 MPG according to my SG2. I installed the new wheels, which are actually stock wheels that the car originally came with (195/65/15). On the trip back, i averaged 47 MPG, even with about 120 lbs of dead weight from the other wheels.
I know it's just one trip, so it's probably not all that accurate, but i'll keep u guys updated to see if there actually is a noticeable difference with these wheels.
Corolla aeromods thread:
http://ecomodder.com/forum/showthrea...ead-11210.html
Old 10-11-2009, 08:35 AM   #2 (permalink)
Hi,
Are there any differences in diameter?
Old 10-11-2009, 10:40 AM   #3 (permalink)
90 day: 51.82 mpg (US)
Circumference is almost the same - the narrower tires would show 64.8 mph where the old ones showed 65. So the computed distance travelled would actually be a tiny bit less. So going strictly on the math, the MPG would show less on the SG.
You said it! It's tough to resist drawing conclusions from MPG readings that are going to vary normally anyway. Especially after doing a mod.
Civic VX wheels or aftermarket? travr6 EcoModding Central 8 03-07-2010 06:37 PM
VX wheels on my HX mobythevan EcoModding Central 7 06-04-2009 10:26 AM
New wheels and tires! Christ Off-Topic Tech 0 04-13-2009 10:30 PM
New Wheels & Tires trikkonceptz Success Stories 9 11-03-2008 02:05 PM
The finest Chinese cr*p that money can buy. (wheels & tires) lyd EcoModding Central 13 09-30-2008 05:41 PM
