Old 12-05-2009, 02:50 PM   #11 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
The glow plug is not much bigger than a spark plug, It is creating a hot spot in the combustion chamber so that the heat of compression has an easier time of getting the injected diesel up to ignition temperature. There is not much temperature transference from the glow plug to the cylinder.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Fuel efficient (small!) diesel engine for Pickup truck bennelson EcoModding Central 24 10-12-2012 10:15 PM
Mer-Chevy Project: Biofuel 40mpg Pickup bennelson EcoModding Central 128 07-27-2010 07:15 PM
Mercedes diesel non electronic oldbeaver Instrumentation 8 03-04-2010 03:32 AM
Engine Insulation GdB EcoModding Central 5 11-30-2009 03:05 AM
Canceling out pumping losses of throttle governed engines greasemonkee EcoModding Central 60 08-03-2009 05:24 PM
