Old 09-10-2009, 01:10 AM   #1 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Prius 2010 stats
Hi,
We've been tracking Prius 2010 performance and recently confirmed Ken@Japan's report of a 5% error in the MPG display:
I'm still curious about the 'outliers' showing up above 55 MPG but we've only had the car in user hands for just over 100 days. There is a lot more to learn.
I've updated my "off the lot" chart of mph vs MPG using the 5% correction:
We've also collected user data on mph vs MPG and with the correction:
These same numbers are showing up in the user reported, EPA numbers:
We have noticed the Honda Insight, user reported numbers are significantly better than the EPA number. The Insight user reports are still too few but the trend looks good.
I've also updated my hill climb data to reflect the calibration factor:
Their is a growing consensus suggests it takes about 0.9 gallons/10,000 ft at 50 mph to climb a hill BUT we haven't finished our studies. Really, the vehicle has only been in our hands for a little over 100 days.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
Old 09-11-2009, 07:13 AM   #2 (permalink)
Engineering first
Thanks to an excellent find, we've added TDI 'mph vs MPG' data to the high speed 'mph vs MPG' chart from Consumer Reports:
I've also changed the scale on the PriusChat collected 'mph vs MPG' chart so it matches my 'off the lot' numbers (see previous posting.)
Bob Wilson
Old 09-11-2009, 10:53 AM   #3 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
I do love seeing mountains of data, but I have a few questions about, and issues with, your plots.
Is the "actual" data the mpg according to the pump and odometer? There's error in pump data too, but it will be random, not biased, and it'll average out in the long run.
Most of your outliers in the 54-65 mpg range do not look like outliers. They fit the trend pretty well. Also, all of the outliers are on the same side of the trendline, and by excluding them, you move the trendline up. I would actually include them all. If you think one of them represents an incompletely filled tank, you need to throw out that data point and one for the tank that follows it.
That's a pretty scandalous conclusion: The Prius' onboard instrumentation lies about MPG. Is Toyota aware that the community is aware of this? I would write them a letter.
If the transmission had discrete gears, plot 3 would be simpler, and I'd slap you for fitting a high-order polynomial to it. In fact, I think I will anyway. Gears or no gears, work (y) required to go speed (x) is a parabola, and your trendline should be as well. Also, what's up with the guy at 50mph, 70mpg? Is he P&G'ing, or aeromodding, or lying, or what?
When I make mpg vs mph plots, I definitely use gal/mi vs mph. I believe they make more intuitive sense that way.
Plot four: it's good to see the numbers confirm what I had been hoping: The Insight outperforms EPA estimates, and while it doesn't beat the Prius, it's not a total embarassment to Honda.
Plot five: What happens when you compare your hill-climb data to mpg vs mph on flat land? At what speed to you most efficiently convert gasoline to gravitational potential energy, and how dramatic is the difference across the range of speeds you would consider climbing hills? And what's up with the second line where the guy gets better mpg at 88mph than at 83mph?
What are you using to gather data to the 0.0001 of a gallon? That's pretty impressive. Me, I'd like to hook up an ABS wheel speed sensor to a data acquisition card and measure the energy consumption of a pothole.
Old 09-11-2009, 12:34 PM   #4 (permalink)
Engineering first
Hi Robert,
I always enjoy reading informed comments:
We are using the pump and trip meter for calculated and the vehicle indicated MPG.
Throwing out the outliers is always risky and the first passes, I tossed out the upper 5% and lower 5%. My theory being that errors at the extremes have an inordinate effect on the line. But as the number of samples increased, I noticed the trend line was approaching a slope of 0.85 with a Y axis intercept approaching 5.
Fortunately, Ken@Japan reported a conversation with a Toyota engineer that the error was 5%. Suddenly it made sense. The Y-axis offset, 5, was approaching 10% of the mid-point value, ~50 MPG. So the offset was tossing the slope the wrong way. I quickly plotted the distribution of errors and sure enough, the upper 10% started at a slope of 45 degrees, the "knee in the curve." So I changed the outlier definition and you see that curious grouping of outliers.
So with Ken's report and the current chart showing ~5% error, you reach a point of diminishing returns. As Dick Hicks, one my GE managers once said, "90% isn't good enough, it is perfect!"
We believe they are. I've not written mine since I'm not sure there is a standard for MPG accuracy.
All I can do is use the data that is available. It isn't as if there a pile of money riding on the results. <grins>
I know and my BSFC charts are that way. But when dealing with folks who have an "MPG" meter, well I try to communicate without getting bogged down in a lesson on physics or thermal dynamics.
This is something that bothers me, the absence of an 'mph vs MPG' chart in the owner's manual. Knowing the 'knee in the curve,' I choose to drive 65 mph on the highway and 70,000 miles later, 52 MPG. But I had to make my own chart to see this relationship. I would rather see a graph than those EPA numbers.
For the Insight owners, they too can choose peak efficiency speeds on the interstates and highways ... if they know what it is. In the City, it looks like they have no problems.
Those were two different octanes, 89, the top curve, and 87, the bottom. What happens is 87 octane appears to have more energy per unit so mileage is best in ordinary driving with 87. But 89 octane allows the engine to tune to the 'knock' sensor. So going up the hill at high speeds, the Prius does not have to draw on traction battery energy. If you draw too much energy from the traction battery, the car slows down ... it still climbs but not like before.
If I'm going to drive in the mountains, I'll switch to a higher octane so I won't put as much stress on the traction battery. But once I get to the 'flat land,' I'm back to 87 octane.
The fuel pump reports .001 gallons on the receipt. You're right that the distance accuracy could cause a loss of resolution but I've got GPS, trip meter, and map readings of the distance. Toss a coin and I could have gone either way. But there is a basis of estimate, the pump receipts.
Bob Wilson
Old 08-09-2010, 03:13 AM   #5 (permalink)
emission data
Hi there,
I'm researching about emission data of different prius generation and I wanna compare emission data of prius 2010 pre and post catalyc converter. could you please help me in this regard?
Old 08-09-2010, 11:51 AM   #6 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Hey there Bwilson. I'm not really 100% up on everything, but from what I know on CleanMPG is that there are 3 batches of "Prius III" HSI controllers.
The first batch was 5~6% high, across the board.
Batch 2 was ~3%
Now, they are within 1%.
2010 Prius – 6 mpg FCD vs. actual FE over report… - CleanMPG Forums
Old 08-09-2010, 12:02 PM   #7 (permalink)
Engineering first
Hi,
I read the thread but didn't see any model identifier or TIS describing how to get an 'accurate' HSI. Regardless, I've always used the pump calculate for my vehicle data. The indicated is only used for short, A-B-A tests.
FYI, I have an Auto Enginuity scanner which appears to report MAF flow accurately. This means I can with the GPS mouse, calculate true MPG vs mph. Just at +90F temperature, these results would be skewed . . . too optimistic. I'm waiting for cooler weather before retesting.
Bob Wilson
Old 08-09-2010, 12:19 PM   #8 (permalink)
Toyota never admitted there was an issue, so I doubt you'll find part numbers.
Old 08-09-2010, 12:24 PM   #9 (permalink)
Engineering first
Originally Posted by Nevyn View Post
Honda never admitted there was an issue, so I doubt you'll find part numbers.
Good deal!
I don't drive a Honda.
Bob Wilson
Old 08-09-2010, 03:33 PM   #10 (permalink)
Barf. Fixed.
Gen III 2010 Prius Matt Herring Hybrids 3 08-30-2010 03:04 AM
Calibration of 2010 Prius MPG indicator bwilson4web Instrumentation 9 05-07-2010 12:13 AM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
2010 Prius unveiled: Cd 0.25, 50 mpg EPA combined, EV mode MetroMPG Hybrids 56 07-26-2009 03:48 PM
2010 Prius with Sunroof open...aero? Matt Herring Aerodynamics 11 06-10-2009 02:57 PM
