Old 06-09-2022, 10:06 PM   #11 (permalink)
Feather Foot
Handsome Jack's Avatar
Snot rocket - '95 Toyota Tercel DX
90 day: 44.77 mpg (US)
Gas Hog - '05 Ford E-250 Extended Cargo
90 day: 20.71 mpg (US)
White Lightning - '09 Toyota Prius base
90 day: 56.31 mpg (US)
seating pizza pan moon caps on a prius
You make a good point about how important it is to snap in the prius moon caps with your hands around the edges only where the screws are. You don't want to dent up your new pizza pans banging them on in the center. There is no support there. Tap them in with the heel of your hand on the edge where the screw are till the trim ring is seated flush.
The Following User Says Thank You to Handsome Jack For This Useful Post:
freebeard (06-09-2022)
Old 06-10-2022, 04:45 PM   #12 (permalink)
Righteous Imaginarian
Talos Woten's Avatar
Champrius v3.2 - '09 Toyota Prius
90 day: 58.73 mpg (US)
I'm leery of anyone besides me touching the hubcaps now, which is why I'm making them a permanent install. I got two new tires a few months ago... and the mechanic saw the screws on my hubcaps and started unscrewing them. If I hadn't been outside taking a walk and stopped him, he would have seriously hosed the hubcaps.
Currently building Champrius 4.0! Follow starting here:
https://www.instagram.com/p/CeeL6xyFp-k/
and ask in depth questions here:
https://ecomodder.com/forum/showthre...tml#post669277
The goal is 70 mpg this time around.
Stats from Champrius v3.2:
