Old 05-31-2022, 02:39 PM   #71 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Originally Posted by Blacktree View Post
Florida is called the sunshine state, for good reason. At this latitude, the sunlight is more direct. And it can be absolutely brutal.
I don't have much to report, regarding the Prius. I took a mini-vacation for my birthday. When I got back home, there was a trailer hitch waiting for me. So I installed it.
Also, the car just gave a P1121 error code. I think that's for the coolant control valve. Looks like it controls coolant flow through the heater core and the thermos bottle. So I ordered a replacement.
Like I mentioned earlier, the BMW is about to undergo major surgery. The Prius eco-mods will be put on hold, while I focus on that. But I'll try to work in some maintenance on the Prius... like the aforementioned water valve, and the front control arms.
Edit to add: I forgot to mention, so far the upper grille block has not caused any overheating. The highest coolant temperature I've seen is 90*C. And the ambient temperatures are 90-95*F. Yep, I just mixed units. LOL
More like the rainiest state in America!
Old 05-31-2022, 06:54 PM   #72 (permalink)
Blacktree's Avatar
The Prius Experiment - '07 Toyota Prius Base
90 day: 58.52 mpg (US)
According to this list, we're #5: https://www.worldatlas.com/articles/...f-america.html
Today, I got a new trouble code (P1116). That appears to refer to the thermos bottle temperature. And I'm guessing it's related to the P1121, since the control valve controls coolant flow through the thermos bottle. So either the wiring connection on the control valve is bad, or the valve itself is bad. Anyway, I have a new control valve. So we'll have to get that installed soon.
The Following User Says Thank You to Blacktree For This Useful Post:
redpoint5 (05-31-2022)
Old 05-31-2022, 07:11 PM   #73 (permalink)
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
Another thing worth checking is any hoses if there are any. Dry rotted and cracked/broken hoses could throw off the pressure/vacuum readings. Don't know anything about that sensor but figured it's worth mentioning.
Old 05-31-2022, 07:11 PM   #74 (permalink)
90 day: 29.78 mpg (US)
I ran a full grill block 3 seasons (in my gen III) and never overheated, and only once noticed the cooling fan kick on as I continually ascended Mt. Hood from Hood River.
woodstock74 (03-23-2023)
Old 06-02-2022, 04:40 PM   #75 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Yup same. I towed from 100k to 190k with my prius. Bass boat, jet skis, trailer with two motorcycles, fridges, washer and dryer, boat motors, etc... All with the grill blocked. Highest temp i ever saw was 202F. They are pretty good at towing too if you keep it below like 1100 pounds.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 06-03-2022, 12:57 PM   #76 (permalink)
Blacktree's Avatar
My little trailer has 1090 lb capacity, so it should be fine.
Old 06-03-2022, 02:19 PM   #77 (permalink)
Over seas they are rated for around 1600 lbs. They can haul more than you'd think, just not exactly within their design limitations lol.
The Following User Says Thank You to ps2fixer For This Useful Post:
freebeard (06-03-2022)
Old 06-03-2022, 02:24 PM   #78 (permalink)
I think this is where that guy got the idea from, Toyota's have build integrity lol.
Old 06-03-2022, 03:43 PM   #79 (permalink)
Negatory.
The Hilux can't turn 360 degrees. It would be the 1974 Gold Superbeetle camper.
tinyhousetalk.com/1974-vw-beetle-towing-custom-5th-wheel-camper/
You can't be wise and in love at the same time. -- Bob Dylan
Old 06-03-2022, 05:35 PM   #80 (permalink)
I was talking about the grossly overloaded vehicle concept lol.
