Old 08-19-2010, 11:49 AM   #31 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
got a link handy?
Old 08-19-2010, 11:39 PM   #32 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
http://focus.ti.com/general/docs/lit...Number=slua411
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
Old 08-20-2010, 12:05 AM   #33 (permalink)
dcb
needs more cowbell
dcb's Avatar
Ah, I did see that, thx. I remember saying "wow did they overcomplicate that!"
I'm hoping something a bit more like one of these will work as a current source (and not take much more than a bridge and caps from the wall as input)
Old 08-20-2010, 08:25 AM   #34 (permalink)
Engineering first
Agreed, it is complicated but I thought they were trying to use the battery charger chip to moderate the switching power supply output. This avoids the efficiency hit of a linear or transistor/MOSFET regulating power via current limiting resistors.
For tickle charging, I would just limit the voltage and let the batteries reach stasis. Low current at a fixed voltage and the problem is solved.
Bob Wilson
Old 08-20-2010, 09:04 AM   #35 (permalink)
dcb
needs more cowbell
dcb's Avatar
mostly the chip was to protect the batteries. If I can string 4 modules together and put an amp through them cheaply and without destroying the batteries, I can recharge in 7 hours ish. This is for a bike/scooter sized experiment so I'm not overly concerned w/efficiency yet, though I will certainly revisit it after looking at the kill-a-watt and the odometer.
Old 08-20-2010, 11:51 AM   #36 (permalink)
dcb
needs more cowbell
dcb's Avatar
here is a constant current controlled by an atmega, I should start there, as that looks like it makes it a software problem (as in bugs=smoke) to add some smart logic (i.e. peak detection, pulse trickle), and even has a separate voltage for the batteries. And I have a small pile of atmegas.
http://www.opend.co.za/hardware/nimh1/nimh1.htm
I'm gonna need a new thread though...
Old 08-23-2010, 10:19 AM   #37 (permalink)
Engineering first
You might also look at the MAXIM712/713.
Bob Wilson
DIY "Mild" Plug-in Prius Project: Grid-powering the 12v side w/ deep cycle batteries orange4boy Hybrids 82 02-25-2016 11:49 AM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
More smaller batteries vs. Less bigger batteries GooberPea Motorcycles / Scooters 34 02-04-2014 02:56 PM
Prius fatal accident rate bwilson4web Hybrids 22 02-05-2010 11:23 PM
Hybrids- A DANGER to the environment! Hermie Hybrids 35 09-10-2009 03:04 PM
