EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Project: Del Sol Kammback Trial Mockup (https://ecomodder.com/forum/showthread.php/project-del-sol-kammback-trial-mockup-7587.html)
jedi_sol 03-24-2009 05:13 PM
5 Attachment(s)
So I got the idea of putting a kammback on the back of my Del Sol thanks to some senior members of this forum. Here's what I was able to do with a couple hours of time and cardboard.
Do you guys think its worth continuing (perfecting?)
jedi_sol 03-24-2009 05:14 PM
5 Attachment(s)
Pics continued
jedi_sol 03-24-2009 05:17 PM
5 Attachment(s)
pics continued 01
jedi_sol 03-24-2009 05:18 PM
3 Attachment(s)
Pics continued 02
SVOboy 03-24-2009 05:42 PM
What's the angle on it? It would be worth fiberglassing with a lexan window for sure if the airflow is attached. Nice work!
PS: I think the angle might be a little too steep. Run some tuft testing trials and see.
jedi_sol 03-24-2009 05:49 PM
1 Attachment(s)
Angle from roof to trunk is approx 14*.
My first concept image has an angle of 11*.
PS: I haven't done anything scientific about this project, I was just testing a mockup to see if it's worth continuing.
Thanks for all of your input.
groar 03-25-2009 02:53 PM
great :thumbup:
do you feel a difference in your car behavior ?
With my rear wheel skirts, the car coasts longer and I feel the car more nervous.
Denis.
PS I note the idea of using double side tape to second the single side tape to attach the coroplast more securely when I'll try a coroplast kammback.
NeilBlanchard 03-25-2009 03:52 PM
Hi,
It might help to try and curve the initial transition off the back of the roof?
aspera 03-29-2009 09:50 AM
Clear engine lid cover/fastback style for the MR2? - NASIOC
The rear window area of a Del Sol is similar to an SW20 MR2. Check out what the MR2 guys in Japan have done. You won't need slots because you don't have a hot engine back there. ;)
Christ 03-29-2009 09:02 PM
Hm... amazing how the DelSol starts looking like a CRX when you put a kamm on it...
Looks great! I don't think Lexan would be too far off for a good looking customization that would also improve aero substantially.
