Old 11-03-2011, 10:52 AM   #31 (permalink)
I thought about fiberglassing the whole thing, and that might have worked had I done it right off the bat. However, its now mashed and disformed from holding it while sanding. So, that is no longer an option for me. The only thing you'd have to be careful with if you did do it that way would be fitment issues. Since the foam expands between the grill's slats, you would need to sand that foam down before putting fiberglass over the top otherwise it might not fit back on well. I'd think it would also probably scratch the paint on the grill slats if you are worried about that.
Old 11-03-2011, 12:24 PM   #32 (permalink)
Quasi-Modder
Another thing a person could do is to lay the glass mat right on the aluminum foil. Let it set up; then fill it with foam to the thickness you need; sand down the foam then glass over it.
The Following 4 Users Say Thank You to Quasimoto For This Useful Post:
aerohead (11-05-2011), Daox (11-03-2011), ECONORAM (05-05-2012), ncc74656m (11-03-2011)
Old 11-03-2011, 12:28 PM   #33 (permalink)
Zerg Lurker
Excellent idea, Quasimoto!
Old 11-03-2011, 12:33 PM   #34 (permalink)
Yes, that would have worked much better than what I did. New ideas for next time!
Old 11-03-2011, 12:34 PM   #35 (permalink)
Zerg Lurker
Or for me! :P
I love my Corolla (now), but I really would like to do something for a little bit better mileage...
Old 11-03-2011, 12:44 PM   #36 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
In order to avoid the foam to be crushed while sanding, I kept it on the upper grille for support (which is removable on my car), especially when I applied the epoxy resin coatings. That way, the foam maintains its shape and it is not damaged in any way. I did not use fibreglass though. Seems to be quite solid without it, even after a few months of usage. We will see how it handles the winter.
The Following 2 Users Say Thank You to CigaR007 For This Useful Post:
Old 11-03-2011, 04:09 PM   #37 (permalink)
VFAQman
talonts's Avatar
I say don't worry about the back. Carve it out, glass in some rare earth magnets, and put some brackets in the nose with matching magnets. Easy removal, but will stay put. Well, easy removal if you don't go too large on the magnets ;-)
You can put foam tape on the back to protect the grille if needed.
Tom Stangl
* http://www.vfaq.net/
* Prius Visual FAQ Home
* 04 Prius AM #7
* 06 Prius NL #7
* http://www.vfaq.com/
* DSM Visual FAQ home
* 90 Talon AWD Turbo
The Following 2 Users Say Thank You to talonts For This Useful Post:
aerohead (11-05-2011), ECONORAM (05-05-2012)
Old 11-03-2011, 04:12 PM   #38 (permalink)
Yeah, I was thinking some foam tape would work nice for protecting the car's paint once it was done.
Magnets would be a cool way to attach it too.
The Following User Says Thank You to Daox For This Useful Post:
BamZipPow (11-04-2011)
Old 11-03-2011, 06:25 PM   #39 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
finally, some areo mods with a clean look to them..
And it didn't cost a while lot to do..
i want to mod my Corolla, but retain some sort of clean look..
I'll be doing something like this as soon as I find a doner grill..
Old 11-05-2011, 01:42 PM   #40 (permalink)
F8L
F8L's Avatar
F8L's 2012 Prius - '12 Toyota Prius Three with Solar Roof
90 day: 62.14 mpg (US)
That is going to look a lot nicer than our typical grille block method.
Here is the method most of use Prius owners run:
2012 Prius Three with Solar Roof - Blizzard Pearl w/dark gray interior: Prius Plug-In 15" Wheels | Michelin Energy Saver A/S 195/65/15 tires | TRD Lowering Springs | WeatherTech FloorLiners | Scangauge II | Morimoto/DDM HIDs 5000K | Clazzio Leather Seat Covers | Best Tank: 71.7mpg@702miles | Best Trip: 95.9mpg@233miles
