Old 07-29-2015, 03:47 PM   #11 (permalink)
DSGs have fantastically short shift times... close enough to instantaneous that you can't tell the difference. The issue, however, is that you only get instant shifts because the next gear is attached to the second clutch... try a double downshift and things get as slow as (or slower than) a regular automatic.
And many DSGs have issues in low speed traffic, where the clutches take on a binary "on-off" character. One reason I would never buy a Fiesta dual clutch.
Single clutch autos... as others have said... learn to lift off between shifts and blip on downshifts, and you're fine. Best in manual mode... so you can synchronise these things... leave it in auto and things get very clunky... and shift times get very long.
No-clutch... been there, too... amusing to see how far you can drive in traffic before you're forced to use the clutch pedal...
Old 07-29-2015, 04:05 PM   #12 (permalink)
My lupo has an automated clutch, its only as good as the mapping/software which IMHO is usually ****, as per every manufacturers system that has gone so far. The DSG systems however are a lot better
Black Lupo 3L 1.2tdi Manual converted the windsurfing bus!
Kermit the Lupo 3L 1.2 Tdi with a current mpg record of 114mpg (imperial) Now sold
G1 JDM Insight I hate the ride but love the quirkiness
Old 07-29-2015, 09:30 PM   #13 (permalink)
I'm a bit confused. It can run in EV only mode? Does the 48v motor drive the trans directly, or does it spin the motor with the fuel injection off? That seems rather wasteful, unless it closed the valves on all cylinders like partial cylinder deactivation does with just some.
I still think the best way to go is a small fwd manual with a small motor driving a light rear diff. THis would allow slow and stop and go ev operation, regen and when needed 4x4.It could be added to existing designs with very little modification.
Old 07-30-2015, 10:23 PM   #14 (permalink)
Peugeot already uses it in production models, but they use an AMT instead of a simple MT.
quire
