Old 10-07-2012, 09:16 AM   #41 (permalink)
Meelis11 link has an option to display mpg or metric. Thats why I said that.
Old 10-07-2012, 11:09 AM   #42 (permalink)
Ranger - '94 Ford Ranger XLT 4WD
90 day: 19.99 mpg (US)
I bought a unit from Meelis. I'm happy with it. It works well and his custom coding is nice. I haven't had any issues yet with freezing as some have reported with other versions. Only thing I wish I had different would be the usb connection so I could do some data logging, but I think I can do without it. I do have an issue with my VSS signal, but that is with my vehicles vss, nothing to do with the mpguino unit.
The Following User Says Thank You to ChadB For This Useful Post:
ECONORAM (11-23-2012)
Old 10-08-2012, 03:15 AM   #43 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
Thanks for feedback. What is a problem with VSS? If it is unstable (jumps around when driving faster) then you can play with "VSS delay" setting. I think default was 2.
If VSS jums around then you can try to increment this one at a time. For my car it was possible to increase it until 5 then delay was too long and VSS started to show 0 speed. Anyways, I added stabilizing capacitor in my mpguinos and after that speed was stable and I didnt have to change VSS delay anymore.
Meelis
http://mpguino.wiseman.ee/eng - get assembled mpguino from here!
Old 10-08-2012, 08:16 AM   #44 (permalink)
My speed did jump around at first, but switching the delay to 0 fixed that. My problem is it reads 0 if I'm going under 15 mph. I've searched around here at it seems this is a common issue with some older vehicles speed sensors like my ranger. It sounds like replacing my vss with a newer style may be the answer.
